Can anyone confirm the following for me. I work for a company that we take care of 178 houses. It is common to have the freezer drain plug up with ice causing water to enter lower section. I had one today that was checked out and the defrost cycle is working properly. Now I have been told that if the freezer is packed too tight with food and does not have enough air circulation that, that can cause the same situation.
