| » Fridge issue |
Model Number: kbrs22kgwh14 Brand: Kitchen Aid Age: More than 10 years
Hi, fridge is not working. Compressor seems to be running, it is a low vibration, not sure what it should be. There is no continuity between the three probes and teh side of the compressor. In the freezer compartment, one side of the coil gets cool to the touch, not cold. It starts to get condensation, but never freezes. Could it be the starter, or is it a sealed system failure? Anything else I can try?
Thanks, Bob Ads By Google Related Models |
There is no continuity between the three probes and teh side of the compressor. The above is confusing if I am interpreting it correctly. If "no continuity between the three probes and teh side of the compressor" is a typo and should be no continuity between the three probes on the side of the compressor. then I do not know how it can be vibrating as all the windings in the compressor are shot (open) In the freezer compartment, one side of the coil gets cool to the touch, not cold. It starts to get condensation, but never freezes. Could it be the starter, or is it a sealed system failure? If we assume that the compressor is indeed running then you have a sealed system problem. If the compressor runs, the evaporator coils should frost up. Also your symptom of only part of the evaporator coil gets cool points to a sealed system problem.
__________________
Quote:
Thanks for the answer. Bob |
It is vibrating so it is running.
Unfortunately it does sound like it is running so I feel you have a sealed system problem. Another clue that it is running is that part of the evaporator coil cools, if the compressor was off you would get zero cooling. A sealed system problem will be an expensive repair as you need a pro. Often it makes more sense to put those dollars towards a new unit. coil is cool to the touch but never frosts up (how long does that take?). A hour is plenty of time for it to frost up. Is there anyway to test the starter relay? Here is a good site on how to check things. How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com If the relay seems to be OK then often the only way to test it properly is to replace it. In your case I do not think it is a relay problem.
__________________
| Display Modes | |
| Whirlpool fridge cooling issue | Bill F | Refrigerator & Freezer Repair | 7 | 07-20-2012 01:52 AM |
| WhirlPool In Fridge Icemaker Issue | cpicard71 | Refrigerator & Freezer Repair | 0 | 01-25-2011 05:04 PM |
| Help me with cooling issue for my fridge | etoth | Refrigerator & Freezer Repair | 1 | 01-12-2011 03:11 AM |
| GE Profile fridge cooling issue, freezer ok | dskratz | Refrigerator & Freezer Repair | 18 | 12-09-2009 10:14 AM |
| Fridge lights issue | rivers76 | Refrigerator & Freezer Repair | 1 | 09-14-2009 11:00 AM |
