I ve had my frig worked on so much i should have bought a new one but it 1 1/2 yr old first it wouldnt cool the guy replaced the box (it had beeen recalled 3 times now its freezing everything the dmper worked now nothin is working the cold control knob has no effect the damper never cycles it just runs the guy said no way to tell start replacing cold control damper timer so on there s got to be away to test these parts maybe he hooked it up wrong he said he had to change the wireing harness please i need some help
