Discuss
GE inverter, inverter wires, and hot compressor
 in
Refrigerator & Freezer Repair
This issue concerns a GE Monogram Side by Side. The machine was running but not cooling. A GE service tech
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » GE inverter, inverter wires, and hot compressor
  #1 (permalink)
Old 08-16-2012, 11:13 AM
Junior Member
rcatty is on a distinguished road
Default GE inverter, inverter wires, and hot compressor
Model Number: ZISS420DR/SS   Brand: GE   Age: 5 - 10 years
This issue concerns a GE Monogram Side by Side. The machine was running but not cooling. A GE service tech came out and stated that the inverter was bad, and therefore the compressor was not running. He gave me the inverter part number, and a few days later I installed same. The machine began to immediately work. It took about 15 hours to reach proper cooling temp levels. Two questions. First, I noticed the compressor is very hot. IS that normal? IF so, what would prevent the compressor from igniting any flammable material in the upper compartment (wires, wire connectors, upper insulation panels etc) ? It seems very hot. You can't leave your hand on it as you will get burned. Secondly, I went to fasten the loose wires from the inverter to their connections via a plastic wire holder/clip, and when bending the wires, it seemed that the compressor stopped working. I loosened the clip and straightened out the wires and it worked. A day later I went to fasten the wires down again, and the compressor seemed to stop working again. Finally, I again loosened everything and the compressor started up. Here is my question: are these wires that sensitive that they have to be clamped a certain way? Will bending stop the current in these wires. Is this normal? The wires I am referring to are the two sets of wires and the ground wires from the inverter to their matching connections. Thank you
Ads By Google
Related Models
General Electric ZISS420DRASS Refrigerator
General Electric ZISS420DRBSS Refrigerator
General Electric ZISS420DRCSS Refrigerator
General Electric ZISS420DRDSS Refrigerator
General Electric ZISS420DRESS Refrigerator
General Electric ZISS420DRFSS Refrigerator
General Electric ZISS420DRGSS Refrigerator
General Electric ZISS420DRHSS Refrigerator
General Electric ZISS420DRISS Refrigerator
General Electric ZISS420NMA Refrigerator
General Electric ZISS420NMB Refrigerator
General Electric ZISS420NMC Refrigerator
General Electric ZISS420NMD Refrigerator
General Electric ZISS420NRASS Refrigerator
General Electric ZISS420NRBSS Refrigerator
General Electric ZISS420NRCSS Refrigerator
General Electric ZISS420NRDSS Refrigerator
General Electric ZISS420NRESS Refrigerator
General Electric ZISS420NRFSS Refrigerator
General Electric ZISS420NRGSS Refrigerator
General Electric ZISS420NRHSS Refrigerator
General Electric ZISS420NRISS Refrigerator
General Electric ZISS42DAASS Refrigerator
General Electric ZISS42DCASS Refrigerator
General Electric ZISS42DCBSS Refrigerator
General Electric ZISS42DYASS Refrigerator
General Electric ZISS42NAASS Refrigerator
General Electric ZISS42NCASS Refrigerator
General Electric ZISS42NCBSS Refrigerator
General Electric ZISS480DMA Refrigerator
General Electric ZISS480DMB Refrigerator
General Electric ZISS480DMC Refrigerator
General Electric ZISS480DMD Refrigerator
General Electric ZISS480DRASS Refrigerator
General Electric ZISS480DRBSS Refrigerator
General Electric ZISS480DRCSS Refrigerator
General Electric ZISS480DRDSS Refrigerator
General Electric ZISS480DRESS Refrigerator
General Electric ZISS480DRFSS Refrigerator
General Electric ZISS480DRGSS Refrigerator
General Electric ZISS480DRHSS Refrigerator
General Electric ZISS480DRISS Refrigerator
General Electric ZISS480NMA Refrigerator
General Electric ZISS480NMB Refrigerator
General Electric ZISS480NMC Refrigerator
General Electric ZISS480NMD Refrigerator
General Electric ZISS480NRASS Refrigerator
General Electric ZISS480NRBSS Refrigerator
General Electric ZISS480NRCSS Refrigerator
General Electric ZISS480NRDSS Refrigerator
General Electric ZISS480NRESS Refrigerator
General Electric ZISS480NRFSS Refrigerator
General Electric ZISS480NRGSS Refrigerator
General Electric ZISS480NRHSS Refrigerator
General Electric ZISS48DAASS Refrigerator
General Electric ZISS48DCASS Refrigerator
General Electric ZISS48DCBSS Refrigerator
General Electric ZISS48DYASS Refrigerator
General Electric ZISS48NAASS Refrigerator
General Electric ZISS48NCASS Refrigerator
General Electric ZISS48NCBSS Refrigerator
General Electric ZISW360DMA Refrigerator
General Electric ZISW360DMB Refrigerator
General Electric ZISW360DMC Refrigerator
General Electric ZISW360DMD Refrigerator
General Electric ZISW360DRA Refrigerator
General Electric ZISW360DRB Refrigerator
General Electric ZISW360DRC Refrigerator
General Electric ZISW360DRD Refrigerator
General Electric ZISW360DRE Refrigerator
General Electric ZISW360DRF Refrigerator
General Electric ZISW360DRG Refrigerator
General Electric ZISW360DRH Refrigerator
General Electric ZISW360DRI Refrigerator
General Electric ZISW36DCA Refrigerator
General Electric ZISW36DCB Refrigerator
General Electric ZISW36DRB Refrigerator
General Electric ZISW36DRC Refrigerator
General Electric ZISW36DSB Refrigerator
General Electric ZISW36DSC Refrigerator
General Electric ZISW36DTB Refrigerator
General Electric ZISW36DTC Refrigerator
General Electric ZISW36DTE Refrigerator
General Electric ZISW36DWA Refrigerator
General Electric ZISW36DXA Refrigerator
General Electric ZISW36DYA Refrigerator
General Electric ZISW36DYB Refrigerator
General Electric ZISW420DMA Refrigerator
General Electric ZISW420DMB Refrigerator
General Electric ZISW420DMC Refrigerator
General Electric ZISW420DMD Refrigerator
General Electric ZISW420DRA Refrigerator
General Electric ZISW420DRB Refrigerator
General Electric ZISW420DRC Refrigerator
General Electric ZISW420DRD Refrigerator
General Electric ZISW420DRE Refrigerator
General Electric ZISW420DRF Refrigerator
General Electric ZISW420DRG Refrigerator
General Electric ZISW420DRH Refrigerator
General Electric ZISW420DRI Refrigerator
General Electric ZISW42DCA Refrigerator
General Electric ZISW42DCB Refrigerator
General Electric ZISW42DSB Refrigerator
General Electric ZISW42DSC Refrigerator
General Electric ZISW42DSE Refrigerator
General Electric ZISW42DWA Refrigerator
General Electric ZISW42DXA Refrigerator
General Electric ZISW42DYA Refrigerator
General Electric ZISW42DYB Refrigerator
General Electric ZISW42EMB Refrigerator
General Electric ZISW42EMC Refrigerator
General Electric ZISW480DMA Refrigerator
General Electric ZISW480DMB Refrigerator
General Electric ZISW480DMC Refrigerator
General Electric ZISW480DMD Refrigerator
General Electric ZISW480DRA Refrigerator
General Electric ZISW480DRB Refrigerator
General Electric ZISW480DRC Refrigerator
General Electric ZISW480DRD Refrigerator
General Electric ZISW480DRE Refrigerator
  #2 (permalink)
Old 08-16-2012, 01:22 PM
Simon / APP Team's Avatar
Expert
Simon / APP Team will become famous soon enough
Default
Hi.
The bending should not affect the conductivity of the wires.
Most likely the plug or the wire is damaged.
Bad connection may cause the compressor to overheat.
But first check if the condenser fan motor is running and if the condenser itself is clean of the lint and dirt.
Thank you. Post the results.
Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Inverter board moleary Microwave Repair 5 06-13-2011 09:16 AM
Inverter Board? Sena Washer Repair 4 02-21-2011 12:38 PM
Fridge Inverter Noise, compressor won't start PRB123 Refrigerator & Freezer Repair 0 10-11-2010 10:01 PM
Need to replace inverter juniordanger Washer Repair 0 07-22-2010 10:21 PM
Inverter board the same? fisenne Oven Repair (including Ranges and Cooktops) 0 03-05-2010 04:59 PM
