| » Too much water to the icemaker |
Model Number: ksss48fjx00 Brand: Kitchen Aid Age: More than 10 years
I am getting too much water to the icemaker causing it to spill into the bin and down the back wall making an ice flow. I just replaced the filter before writing this. It had not been replaced for a long time; I bought the refrigerator used. In the event that the problem continues would the problem be in the fill valve or more likely in the icemaker itself? After I clean up the ice and restart the icemaker, it doesn't start overflowing right away. It starts when the bin is starting to filll.
Hi.
Make sure that the fill tube isn't touching the inlet wall causing splashing. Adjust the cube size by turning the adjustment screw CW 1/2 turn (remove the head cover to locate the screw). Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
I'm glad you find the problem.
Simon.
__________________
| Display Modes | |
| Whirlpool Fridge Top Freezer Icemaker Water will not stop filling Icemaker | hmslouie | Refrigerator & Freezer Repair | 1 | 07-22-2012 05:49 AM |
| Water Hose No Longer Dispensing Water To The Icemaker | GRACECAZARES | Refrigerator & Freezer Repair | 3 | 08-23-2011 07:59 PM |
| Icemaker - water continues to dispense when Icemaker shut off arm is activated | dpassaro | Refrigerator & Freezer Repair | 0 | 07-24-2011 09:57 AM |
| Icemaker - water continues to dispense when Icemaker shut off arm is activated | dpassaro | Refrigerator & Freezer Repair | 0 | 07-24-2011 09:49 AM |
| water dispenser works icemaker will not fill with water | rchandle | Refrigerator & Freezer Repair | 0 | 05-16-2011 05:36 AM |
