I have removed the back in freezer, manually defrosted it, checked continuity on heater... it's good. I don't see how to check the t stat for continuity since the part has no place to do it. Also, if this t stat is good, can I check the control board or just replace it. Thanks
I would replace the defrost thermostat and the adaptive defrost board behind the control panel.
