Discuss
ge water valve assembly questions
 in
Refrigerator & Freezer Repair
I have determined that the inlet water valve on my refrigerator has a bad solenoid. I have current to the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » ge water valve assembly questions
  #1 (permalink)
Old 09-20-2009, 06:42 PM
Junior Member
mharwell01 is on a distinguished road
Default ge water valve assembly questions
Model Number: TPS248PDA BS   Brand: GE   Age: 5 - 10 years
I have determined that the inlet water valve on my refrigerator has a bad solenoid. I have current to the wire that connects to it, but it doesnt open to allow water through to fill the ice maker tray.
On my refrigerator, the water supply line from the wall connects to a water valve with a single outlet from which a water line goes up to the filter. There is a return line from the filter back to a second water valve that has dual solenoids, one for the ice maker and one for water to the door.
We do not utilize a filter, have always just had the plug installed in its place. So I had the bright idea, that since we dont use the filter, why not just bypass the inlet solenoid and connect the supply water line from the wall directly to the after filter solenoid. After making the connections, I get a steady dribble of water from the door water without even pressing the button.
My first question: shouldnt the solenoid be closed not allowing any water to pass through if there is no current (door water button not pressed)? Are the two water valves wired in a way that they work together or is there some other reason why this doesnt work?
I found the entire water valve assembly that includes both valves for about $60 plus shipping. I found the inlet valve only by itself and the after filter valve by itself also.
My next question: For those who know something about how these things work, is it advisable for me to go ahead and bite the bullet and buy the entire assembly or should I attempt to replace only the inlet valve first?
By the way I did check the supply tube for freezing (it was clear) and the ice maker seems to function fine. If I fill the tray by hand it does everything its supposed to. When it cycles I get current through the wire to the solenoid so I dont think ther is any problem with the ice maker. I put 120v to the solenoid and nothing happened so unless Im missing something I think the problem is with the solenoid.
Your advice/ suggestions would be appreciated.
Ads By Google
Related Models
General Electric TPS24BICABS Refrigerator
General Electric TPS24BICEBS Refrigerator
General Electric TPS24BICGBS Refrigerator
General Electric TPS24BIDABS Refrigerator
General Electric TPS24BPCABS Refrigerator
General Electric TPS24BPCEBS Refrigerator
General Electric TPS24BPCGBS Refrigerator
General Electric TPS24BPCJBS Refrigerator
General Electric TPS24BPDABS Refrigerator
General Electric TPS24PBBABS Refrigerator
General Electric TPS24PBBBBS Refrigerator
General Electric TPS24PBBEBS Refrigerator
General Electric TPS24PBBGBS Refrigerator
General Electric TPS24PBBJBS Refrigerator
General Electric TPS24PBDABS Refrigerator
General Electric TPS24PIBABS Refrigerator
General Electric TPS24PIBBBS Refrigerator
General Electric TPS24PIBCBS Refrigerator
General Electric TPS24PIBEBS Refrigerator
General Electric TPS24PIBGBS Refrigerator
General Electric TPS24PPBABS Refrigerator
General Electric TPS24PPBBBS Refrigerator
General Electric TPS24PPBEBS Refrigerator
General Electric TPS24PPBGBS Refrigerator
General Electric TPS24PPBJBS Refrigerator
General Electric TPS24PPDABS Refrigerator
General Electric TPX21BRBABB Refrigerator
General Electric TPX21BRBAWW Refrigerator
General Electric TPX21BRBBBB Refrigerator
General Electric TPX21BRBBWW Refrigerator
General Electric TPX21BRBCBB Refrigerator
General Electric TPX21BRBCWW Refrigerator
General Electric TPX21BRBEBB Refrigerator
General Electric TPX21BRBEWW Refrigerator
General Electric TPX21BRBGBB Refrigerator
General Electric TPX21BRBGWW Refrigerator
General Electric TPX21BRDABB Refrigerator
General Electric TPX21BRDAWW Refrigerator
General Electric TPX21BRXAAA Refrigerator
General Electric TPX21BRXABB Refrigerator
General Electric TPX21BRXAWW Refrigerator
General Electric TPX21BRXDAA Refrigerator
General Electric TPX21BRXDBB Refrigerator
General Electric TPX21BRXDWW Refrigerator
General Electric TPX21BRXFAA Refrigerator
General Electric TPX21BRXFBB Refrigerator
General Electric TPX21BRXFWW Refrigerator
General Electric TPX21PRBAAA Refrigerator
General Electric TPX21PRBABB Refrigerator
General Electric TPX21PRBAWW Refrigerator
General Electric TPX21PRBBAA Refrigerator
General Electric TPX21PRBBBB Refrigerator
General Electric TPX21PRBBWW Refrigerator
General Electric TPX21PRBCAA Refrigerator
General Electric TPX21PRBCBB Refrigerator
General Electric TPX21PRBCWW Refrigerator
General Electric TPX21PRBEAA Refrigerator
General Electric TPX21PRBEBB Refrigerator
General Electric TPX21PRBEWW Refrigerator
General Electric TPX21PRBGAA Refrigerator
General Electric TPX21PRBGBB Refrigerator
General Electric TPX21PRBGWW Refrigerator
General Electric TPX21PRDAAA Refrigerator
General Electric TPX21PRDABB Refrigerator
General Electric TPX21PRDAWW Refrigerator
General Electric TPX21PRXAAA Refrigerator
General Electric TPX21PRXABB Refrigerator
General Electric TPX21PRXAWW Refrigerator
General Electric TPX21PRXDAA Refrigerator
General Electric TPX21PRXDBB Refrigerator
General Electric TPX21PRXDWW Refrigerator
General Electric TPX21PRXFAA Refrigerator
General Electric TPX21PRXFBB Refrigerator
General Electric TPX21PRXFWW Refrigerator
General Electric TPX24BIBABB Refrigerator
General Electric TPX24BIBAWW Refrigerator
General Electric TPX24BIBBBB Refrigerator
General Electric TPX24BIBBWW Refrigerator
General Electric TPX24BIBCBB Refrigerator
General Electric TPX24BIBCWW Refrigerator
General Electric TPX24BIBEBB Refrigerator
General Electric TPX24BIBEWW Refrigerator
General Electric TPX24BIBGBB Refrigerator
General Electric TPX24BIBGWW Refrigerator
General Electric TPX24BIDABB Refrigerator
General Electric TPX24BIDAWW Refrigerator
General Electric TPX24BIYABB Refrigerator
General Electric TPX24BIYAWW Refrigerator
General Electric TPX24BIYEBB Refrigerator
General Electric TPX24BIYEWW Refrigerator
General Electric TPX24BIYFBB Refrigerator
General Electric TPX24BIYFWW Refrigerator
General Electric TPX24BPBABB Refrigerator
General Electric TPX24BPBAWW Refrigerator
General Electric TPX24BPBBBB Refrigerator
General Electric TPX24BPBBWW Refrigerator
General Electric TPX24BPBEBB Refrigerator
General Electric TPX24BPBECC Refrigerator
General Electric TPX24BPBEWW Refrigerator
General Electric TPX24BPBGBB Refrigerator
General Electric TPX24BPBGCC Refrigerator
General Electric TPX24BPBGWW Refrigerator
General Electric TPX24BPBJBB Refrigerator
General Electric TPX24BPBJCC Refrigerator
General Electric TPX24BPBJWW Refrigerator
General Electric TPX24BPDABB Refrigerator
General Electric TPX24BPDACC Refrigerator
General Electric TPX24BPDAWW Refrigerator
General Electric TPX24BPDBBB Refrigerator
General Electric TPX24BPDBCC Refrigerator
General Electric TPX24BPDBWW Refrigerator
General Electric TPX24BPZBBB Refrigerator
General Electric TPX24BPZBWW Refrigerator
General Electric TPX24BPZCBB Refrigerator
General Electric TPX24BPZCWW Refrigerator
General Electric TPX24BRBAAA Refrigerator
General Electric TPX24BRBABB Refrigerator
General Electric TPX24BRBAWW Refrigerator
General Electric TPX24BRBBAA Refrigerator
General Electric TPX24BRBBBB Refrigerator
  #2 (permalink)
Old 09-21-2009, 09:07 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
...why not just bypass the inlet solenoid and connect the supply water line from the wall directly to the after filter solenoid...
All four solenoids are the same (electrically) but the water valves are different and should be used as assembly.
__________________
Appliance Repair Expert in Orange County, California.
Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com
  #3 (permalink)
Old 10-16-2009, 09:59 AM
Junior Member
jamac is on a distinguished road
Default
I May have same problem, how do I check voltage is going to unit, I have a voltage meter but not sure how to use with this.
Please help thanks
  #4 (permalink)
Old 10-16-2009, 02:49 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Quote:
Please help thanks
What is the complete model number of the refrigerator?
What exactly is wrong?
__________________
  #5 (permalink)
Old 10-17-2009, 04:00 AM
Junior Member
Default kenmore 363.50622000 model
Thanks for reply,
there is no drinking water and no ice being made, I have checked water inlet and there is water coming into water valve, but nothing coming out.
I thought i would have to replace this part, AP2071738 made by GE but i wanted to make sure that power was getting to this part before ordering,
Due to colour of wires, orange, yellow and white coming in from connector not sure what to check and how
Can you help please
  #6 (permalink)
Old 10-17-2009, 05:38 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
How old is the water filter? It does not last more than a year and it would not let water through if clogged.
- The water filter Part number: AP3859302
__________________
  #7 (permalink)
Old 10-18-2009, 05:17 AM
Junior Member
Default
Hi Gene,
I got new filter appx 6 months ago, there appears to be no water going up to filter when switched on, any other thoughts
  #8 (permalink)
Old 10-19-2009, 04:25 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
Remove the wires from the water valve solenoids and check them all for continuity. Check for 120 VAC between the wires connected to the blue solenoids while the water dispenser calls for water. Post the results.
__________________
  #9 (permalink)
Old 10-20-2009, 03:40 AM
Junior Member
Default
Hi gene, how do I do this, ie check for continuity ?
  #10 (permalink)
Old 10-20-2009, 02:37 PM
Gene's Avatar
Senior Expert
APP Volunteer
Default
The following article on our forum will explain in detail how to run a continuity test using either an analog meter or a digital meter - How To Check Continuity With Ohmmeter
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Water Valve Assembly Problem? SoCal12thMan Dishwasher Repair 0 02-20-2010 09:29 PM
ge water valve assembly buffcr39 Refrigerator & Freezer Repair 4 12-14-2009 07:02 AM
Dishwasher water assembly valve bertnhank Dishwasher Repair 1 01-06-2009 07:39 PM
G E refrigerator valve assembly shoots out water RickJ Refrigerator & Freezer Repair 5 10-10-2008 09:01 AM
Replacing water valve assembly on brand new Bosch NickB Dishwasher Repair 2 03-28-2008 03:01 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
