Having problem with water filter leaking. Changed filter. Still leaks. Before I go taking things apart, was wondering if it could be caused by water hammer. After dispensing water, I can hear water line in door lurch pretty good. Don't know if this is when leak occurs or not. Seems to be inconsistent. Can I get a hammer arrestor? If so where do I install it?
