My Maytag french door has worked perfect, Water inside the fridge just stopped working unless I turn off or unplug the fridge a few minutes to allow the temp to raise. The fridge is set at 38 degrees, I tried installing a new water filter as some forums suggested and it was time and the issue still persists. the water runs fine if I allow the temp to raise to 60 or more degrees, the ice maker works great and it cools great There have been no issues ever with any part of this fridge.
