| » Amana: Compressor keeps going |
Make sure the condenser coils are clean and condenser motor running,and the freezer coils have no heavy frost. Measure the stabilized freezer temperature and post, should be below 10 degrees, if not, you have a bad compressor/ refrigerant leak.
__________________
Hi Richappy,
Thanks for your reply. 1. Condensor coils: I removed the toe-plate and cleaned the coils behind it as much as I could (it's never been cleaned before, I suppose) last week. And it doesn't seem to help at all. 2. Condensor motor: Could you tell me where it's located? How can I check if it's running? 3. Freezer coils: I don't see any exposed coils in my freezer. I do see some slits on the back wall. Do I need to take remove the back wall to see them? 4. Freezer temperature: Yes, I will get the thermometer and post back. Thanks again, and sorry for the newbie questions. |
You need to remove the freezer back panel to check the coils. The condenser motor and fan cool the compressor and condensing coils, just check near the compressor.
__________________
hello, last weekend i bought a used amana refrigerator (2 years old) and i have the exact same problem
fridge is idle for 30 min then turns on for 15-20 minutes and the cycle starts again and again... i will have a look at what richappy suggested... dato did you finally fix the problem...? i will come back and update once i have looked at the possibilities... thanks |
| Display Modes | |
| Amana refrig compressor | davesherman57 | Refrigerator & Freezer Repair | 3 | 07-24-2012 06:57 PM |
| Amana compressor motor will not start | blinkedty | Refrigerator & Freezer Repair | 1 | 04-16-2011 06:50 AM |
| Replacing compressor Amana | Lawrence430 | Refrigerator & Freezer Repair | 3 | 05-15-2009 05:21 PM |
| Amana dimensions compressor kicks off | Legend in Your Mind | Refrigerator & Freezer Repair | 0 | 04-25-2009 02:15 PM |
| Amana #341 compressor | msl | Refrigerator & Freezer Repair | 1 | 10-09-2008 09:49 AM |
