Both the refrigerator and freezer seem to be working fine except when the freezer goes through a defrost cycle, the drain is apparently clogged. I've used a hair dryer to attempt to thaw the drain tube as well as used a small bottle brush to try and remove any obstruction. It still seems clogged as the melting frost gathers on the bottom of the freezer and seeps out under the freezer door. Is there a diagram that shows the drain system? Any ideas on how to unclog this drain?
Thanks,
jbacinti
Thanks Gene, I'll give your suggestions a try.
