I have to replace the water Dual inlet valve assembly (#AP4071513). Where is this located and are there any tricks to replacing it?
Thank you for your answer. When you try and use the water lever it takes several seconds before the water comes out and it makes a electrical humming sound. It also seems to be getting worse. I changed the filter and it is still happening.
There are two water valves and it's hard to say which is bad in such situation. The second water valve is located in the back of the refrigerator as well. It supplies water to the water filter. - The filter water valve Part number: 12001892
