Discuss
Wards Refgrator
 in
Refrigerator & Freezer Repair
This is a Signature Series Frost less 18. Freezer works but the Refrigerator get warm after a while. If it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Wards Refgrator
  #1 (permalink)
Old 08-09-2012, 02:35 AM
Junior Member
jph69 is on a distinguished road
Default Wards Refgrator
Model Number: HMG184742A   Brand: Signature   Age: More than 10 years
This is a Signature Series Frost less 18. Freezer works but the Refrigerator get warm after a while. If it sets a few days it will get cold again but then warms up again. The freezer works fine
Ads By Google
Related Models
General Electric HMV24CEWABB Gas range
General Electric HMV24CEWAN Gas range
General Electric HMV24CEWEBB Gas range
General Electric HMV24CEWEN Gas range
Maytag HN41240P Gas Water Heater
Maytag HN41240PCAN Gas Water Heater
Maytag HN41240X Gas Water Heater
Maytag HN41240XCAN Gas Water Heater
Maytag HN41250P Gas Water Heater
Maytag HN41250PCAN Gas Water Heater
Maytag HN41250Q Gas Water Heater
Maytag HN41250QCAN Gas Water Heater
Maytag HN41250V Gas Water Heater
Maytag HN41250VCAN Gas Water Heater
Maytag HN41250VCANZ Gas Water Heater
Maytag HN41250VZ Gas Water Heater
Maytag HN41250X Gas Water Heater
Maytag HN41250XCAN Gas Water Heater
Maytag HN41275P Gas Water Heater
Maytag HN41275PCANZ Gas Water Heater
Maytag HN41275PZ Gas Water Heater
Maytag HN41275Q Gas Water Heater
Maytag HN41275QCAN Gas Water Heater
Maytag HN4830T971 Gas Water Heater
Maytag HN4840S971 Gas Water Heater
Maytag HN4840T971 Gas Water Heater
Maytag HN4850T971 Gas Water Heater
Maytag HN4875S980 Gas Water Heater
Maytag HN4930T Gas Water Heater
Maytag HN4930TCAN Gas Water Heater
Maytag HN4940S Gas Water Heater
Maytag HN4940SCAN Gas Water Heater
Maytag HN4940T Gas Water Heater
Maytag HN4940TCAN Gas Water Heater
Maytag HN4950S Gas Water Heater
Maytag HN4950SCAN Gas Water Heater
Maytag HN4950T Gas Water Heater
Maytag HN4950TCAN Gas Water Heater
Maytag HN4975S Gas Water Heater
Maytag HN4975SCAN Gas Water Heater
Maytag HN4X40P980 Gas Water Heater
Maytag HN4X40P980CGA Gas Water Heater
Maytag HN4X40X960 Gas Water Heater
Maytag HN4X40X960CGA Gas Water Heater
Maytag HN4X50P980 Gas Water Heater
Maytag HN4X50Q960 Gas Water Heater
Maytag HN4X50Q960CGA Gas Water Heater
Maytag HN4X50V980 Gas Water Heater
Maytag HN4X50X960 Gas Water Heater
Maytag HN4X50X960CGA Gas Water Heater
Maytag HN51240P Gas Water Heater
Maytag HN51240PCAN Gas Water Heater
Maytag HN51240X Gas Water Heater
Maytag HN51240XCAN Gas Water Heater
Maytag HN51250P Gas Water Heater
Maytag HN51250PCAN Gas Water Heater
Maytag HN51250Q Gas Water Heater
Maytag HN51250QCAN Gas Water Heater
Maytag HN51250V Gas Water Heater
Maytag HN51250VCAN Gas Water Heater
Maytag HN51250VCANZ Gas Water Heater
Maytag HN51250VZ Gas Water Heater
Maytag HN51250X Gas Water Heater
Maytag HN51250XCAN Gas Water Heater
Maytag HN51275P Gas Water Heater
Maytag HN51275PCANZ Gas Water Heater
Maytag HN51275PZ Gas Water Heater
Maytag HN51275Q Gas Water Heater
Maytag HN51275QCAN Gas Water Heater
Maytag HN5830T971 Gas Water Heater
Maytag HN5840S971 Gas Water Heater
Maytag HN5840T971 Gas Water Heater
Maytag HN5850T971 Gas Water Heater
Maytag HN5875S980 Gas Water Heater
Maytag HN5930T Gas Water Heater
Maytag HN5930TCAN Gas Water Heater
Maytag HN5940S Gas Water Heater
Maytag HN5940SCAN Gas Water Heater
Maytag HN5940T Gas Water Heater
Maytag HN5940TCAN Gas Water Heater
Maytag HN5950S Gas Water Heater
Maytag HN5950SCAN Gas Water Heater
Maytag HN5950T Gas Water Heater
Maytag HN5950TCAN Gas Water Heater
Maytag HN5975S Gas Water Heater
Maytag HN5975SCAN Gas Water Heater
Maytag HN5X40P980 Gas Water Heater
Maytag HN5X40X960 Gas Water Heater
Maytag HN5X40X960CGA Gas Water Heater
Maytag HN5X50P980 Gas Water Heater
Maytag HN5X50Q960 Gas Water Heater
Maytag HN5X50Q960CGA Gas Water Heater
Maytag HN5X50V980 Gas Water Heater
Maytag HN5X50X960 Gas Water Heater
Maytag HN5X50X960CGA Gas Water Heater
Thermador HNI42YS
Thermador HNI48YS
Thermador HNI54YS
General Electric HNSR3110H0WW Washer
Thermador HNW36YS
Thermador HNW42YS
Thermador HNW48YS
Maytag HP41240P Gas Water Heater
Maytag HP41240PCAN Gas Water Heater
Maytag HP41240X Gas Water Heater
Maytag HP41240XCAN Gas Water Heater
Maytag HP41250P Gas Water Heater
Maytag HP41250PCAN Gas Water Heater
Maytag HP41250Q Gas Water Heater
Maytag HP41250QCAN Gas Water Heater
Maytag HP41250X Gas Water Heater
Maytag HP41250XCAN Gas Water Heater
Maytag HP41275P Gas Water Heater
Maytag HP41275PCANZ Gas Water Heater
Maytag HP41275PZ Gas Water Heater
Maytag HP41275Q Gas Water Heater
Maytag HP41275QCAN Gas Water Heater
Maytag HP4830T980 Gas Water Heater
Maytag HP4840S980 Gas Water Heater
Maytag HP4840T980 Gas Water Heater
  #2 (permalink)
Old 08-09-2012, 02:46 AM
Junior Member
Smile
[quote=jph69;761722]This is a Signature Series Frost less 18. Freezer works but the Refrigerator get warm after a while. If it sets a few days it will get cold again but then warms up again. The freezer works fine. Do you think its the glass tube in the defrost cycle
  #3 (permalink)
Old 08-09-2012, 02:56 AM
Junior Member
Angry
[quote=jph69;761723]
Quote:
I would appreciate any help. his unit is built into a wall behind my bar, I would have to lift it over the top of the bar to get it out
  #4 (permalink)
Old 08-09-2012, 04:06 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I cannot find any info on the given model number, please check it.
Fact is if I Google the number all that comes up is your post.
Check that the condenser coils under the unit are clean. Also that the condenser/compressor fan (if it has one) runs when the compressor runs.
With luck you should be able to do this by just removing the kick plate aand using a flashlight.
It would be a good idea to put a thermometer in the freezer to see what the actual temperature is. It should be between 0 and 5 degrees F. The fresh food temperature is highly dependent on the freezer temperature.
Also check that the evaporator/freezer fan is running. It is required to push the cold air into the fresh food section. They can go intermittent.
If it is a defrost problem the compressor will also run all the time except when it goes into a defrost cycle.
If it does not cycle then when it is warm you will have to remove the rear panel in the freezer so you can inspect the evaporator coils. I am guessing this is where they are but some units have the evaporator coils under the freezer floor.
If they are heavily iced/frosted over then you have an intermittent defrost problem. The reason I say intermittent is that a defrost problem will not just repair itself so one of the components in the defrost system is working only sometimes.
On most units the defrost system has 3 parts.
A defrost heater, a defrost thermostat and a defrost timer or adaptive defrost control board.
It would be rare that the heater would go intermittent. Usually if they had an internal open they will burn out at that point.
More likely would be the defrost thermostat. Check it to see if it is deformed/bulged. If it is then it would be the prime suspect.
Could also be the defrost timer motor is sticking occasionally. If by turning the defrost timer cam, you can force the defrost heater on then I would put it at the top of the list. Be careful that you do not burn your fingers. Usual places for the timer is behind the kick plate, you may not be able to see it as it may be attached to a bracket but usually you will at least see a hole that lets you turn the timer cam. Could also be in the control console, here they also usually have a hole. Or may be at the back of the unit behind the rear cover.
If your unit is cycling when it is warm then odds are that the main temperature control thermostat needs replacing.
Also some units have a thermostat controlled damper which regulates the amount of cold air entering the fresh food section. Perhaps if your unit has this it is the cause.
Without some tech info I am just throwing out ideas but I hope they will be useful to you.
__________________
  #5 (permalink)
Old 08-09-2012, 04:29 AM
Junior Member
reenfil is on a distinguished road
Default
Cooked salmon will keep in the fridge for 3-4 days. I wouldn't go over three days just to be on the safe side. If you put cooked salmon in the freezer it will keep for 4-6 months.
try this out
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Montgomery Wards Dryer mover Dryer Repair 0 03-06-2012 01:16 PM
Montgomery wards mini fridge sambonnie Refrigerator & Freezer Repair 2 08-12-2009 07:10 AM
Who made Montgomery Wards Refrig. in '46 ImaBear Refrigerator & Freezer Repair 0 06-27-2009 06:18 PM
Ice maker auger running back wards kimmy Refrigerator & Freezer Repair 0 12-27-2007 04:54 AM
Replace Montgomery Wards Dryer Belt mbcorns Dryer Repair 3 10-18-2007 03:43 AM
