Discuss
Refrigerator not cooling
 in
Refrigerator & Freezer Repair
I have a Danby 9.6 compact fridge. Manual Defrost. It isn't getting cold. I can feel the compressor running, it
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Refrigerator not cooling
  #1 (permalink)
Old 08-08-2012, 06:02 PM
Junior Member
asielaff is on a distinguished road
Default Refrigerator not cooling
Model Number: D9604   Brand: -other-   Age: 5 - 10 years
I can feel the compressor running, it is pretty warm to the touch. I checked the capacitor and it is in the range marked on it. (8 uf) I checked the thermostat (open circuit when turned off and close to 0 resistance when turned on coldest setting. I can hear fluid running through the cooling line that goes next to the freezer but it isn't cold. I can't find any fans (is that possible.?) Everything is clean. Any suggestions what else I can check? Thanks for your help.
Related Models
Roper D9751*1 Ranges, Electric*
Roper D9757*0 Ranges, Electric*
Roper D9757*1 Ranges, Electric*
Roper D9757*2 Ranges, Electric*
Roper D9757*5 Ranges, Electric*
Roper D9757*6 Ranges, Electric*
Roper D9757W0 Ranges, Electric*
Roper D9757W1 Ranges, Electric*
Roper D9757W2 Ranges, Electric*
Roper D9757W5 Ranges, Electric*
Roper D9757W6 Ranges, Electric*
Whirlpool D9757^1
Whirlpool D9757^2
Whirlpool D9757^5
Amana DA1040 WASHER-TOP LOADING
Amana DA3000 WASHER-TOP LOADING
Amana DA3001 WASHER-TOP LOADING
Amana DA3080 WASHER-TOP LOADING
Amana DA3100 WASHER-TOP LOADING
Amana DA3101 WASHER-TOP LOADING
Amana DA3201 WASHER-TOP LOADING
Amana DA3210 WASHER-TOP LOADING
Amana DA3211 WASHER-TOP LOADING
Amana DA3500 WASHER-TOP LOADING
Amana DA3501 WASHER-TOP LOADING
Amana DA3660 WASHER-TOP LOADING
Amana DA3661 WASHER-TOP LOADING
Amana DA3690 WASHER-TOP LOADING
Amana DA3691 WASHER-TOP LOADING
Amana DA3780 WASHER-TOP LOADING
Amana DA3781 WASHER-TOP LOADING
Amana DA3820 WASHER-TOP LOADING
Amana DA3821 WASHER-TOP LOADING
Amana DA6070 WASHER-TOP LOADING
Amana DA6071 WASHER-TOP LOADING
Amana DA6073 WASHER-TOP LOADING
Amana DA6100 WASHER-TOP LOADING
Amana DA6101 WASHER-TOP LOADING
Amana DA6111 WASHER-TOP LOADING
Amana DA6120 WASHER-TOP LOADING
Amana DA6121 WASHER-TOP LOADING
Amana DA6123 WASHER-TOP LOADING
Amana DA6191 WASHER-TOP LOADING
Amana DA6200 WASHER-TOP LOADING
Amana DA6201 WASHER-TOP LOADING
Amana DA6220 WASHER-TOP LOADING
Amana DA6221 WASHER-TOP LOADING
Amana DA6223 WASHER-TOP LOADING
Amana DA6250 WASHER-TOP LOADING
Amana DA6251 WASHER-TOP LOADING
Amana DA9000 WASHER-TOP LOADING
Amana DA9011 WASHER-TOP LOADING
Amana DA9041 WASHER-TOP LOADING
Amana DA9043 WASHER-TOP LOADING
Amana DA9101 WASHER-TOP LOADING
Amana DA9103 WASHER-TOP LOADING
Frigidaire DAFW3577KW0 WASHER
Frigidaire DAFW3577KW1 WASHER
Frigidaire DAQE7077KW0 ELECTRIC DRYER
Frigidaire DAQG7077KW0 GAS DRYER
Admiral DAV1200AWW WASHER-TOP LOADING
Admiral DAV2240AWA WASHER-TOP LOADING
Admiral DAV2240AWW WASHER-TOP LOADING
Frigidaire DB100PD1 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire DB100PW1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB110PW1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB120P1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB200PW1 Frg(v1) / 24 " Built - in Dishwasher
Amana DB2221N WASHER-TOP LOADING
 DB3710DB DISHWASHER- UNDERCOUNTER
 DB3710DW DISHWASHER- UNDERCOUNTER
Frigidaire DB400A1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB400PW1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB418PW1 Frg(v1) / 18 " Built - in Dishwasher
Frigidaire DB418PW2 Frg(v1) / 18 " Built - in Dishwasher
 DB5710DT DISHWASHER- UNDERCOUNTER
Frigidaire DB664RBR0 Wwh(v0) / 24 " Built - in Dishwasher
Frigidaire DB700AW1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB700P1 Frg(v1) / 24 " Built - in Dishwasher
Frigidaire DB700P1-00 Tap(v7) / 24 " Built - in Dishwasher
Frigidaire DB700P1-23 Tap(v8) / 24 " Built - in Dishwasher
Frigidaire DB700PD1 Wwh(v4) / 24 " Built - in Dishwasher
Frigidaire DB700PL1 Frg(v2) / 24 " Built - in Dishwasher
Frigidaire DB700PW1 Frg(v1) / 24 " Built - in Dishwasher
Amana DB7111N WASHER-TOP LOADING
Amana DB7221N WASHER-TOP LOADING
Amana DB8181N WASHER-TOP LOADING
Amana DB8201N WASHER-TOP LOADING
General Electric DBB3300EA0AA Electric dryer
General Electric DBB3300EA0WW Electric dryer
General Electric DBB3300EA1AA Electric dryer
General Electric DBB3300EA1WW Electric dryer
General Electric DBB3300GA0AA Gas dryer
General Electric DBB3300GA0WW Gas dryer
General Electric DBB3300GA1AA Gas dryer
General Electric DBB3300GA1WW Gas dryer
General Electric DBB3300GA2AA Gas dryer
General Electric DBB3300GA2WW Gas dryer
General Electric DBB5000EF0GG Electric dryer
General Electric DBB5000GF0GG Gas dryer
General Electric DBB5000GF1GG Gas dryer
General Electric DBL333EA0AA Electric dryer
General Electric DBL333EA0CC Electric dryer
General Electric DBL333EA0WW Electric dryer
General Electric DBL333EA1CC Electric dryer
General Electric DBL333EA1WW Electric dryer
General Electric DBL333EB0CC Electric dryer
General Electric DBL333EB0WW Electric dryer
General Electric DBL333EB1CC Electric dryer
General Electric DBL333EB1WW Electric dryer
General Electric DBL333EB3CC Electric dryer
General Electric DBL333EB3WW Electric dryer
General Electric DBL333EB4CC Electric dryer
General Electric DBL333EB4WW Electric dryer
General Electric DBL333EB6CC Electric dryer
General Electric DBL333EB6WW Electric dryer
General Electric DBL333EY0AA Electric dryer
General Electric DBL333EY0WW Electric dryer
General Electric DBL333GA0AA Gas dryer
General Electric DBL333GA0CC Gas dryer
  #2 (permalink)
Old 08-09-2012, 04:13 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
If you are sure that the compressor is running and it sounds like you are then you have a sealed system problem.
When the compressor runs the evaporator should get cold.
This will be an expensive repair as you need a pro.
Usually it makes more sense to put those dollars towards a new unit.
With a compact fridge the repair will likely be more than a new unit.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Refrigerator/Freezer stops cooling, then starts cooling, then stops cooling angiebritt Refrigerator & Freezer Repair 4 05-16-2016 05:31 AM
Refrigerator not cooling anwik Refrigerator & Freezer Repair 0 01-16-2012 08:10 AM
REfrigerator on but not cooling cdbrock24 Refrigerator & Freezer Repair 0 06-29-2011 07:14 AM
amana refrigerator not frezzing and refrigerator not cooling didhebiteyou Refrigerator & Freezer Repair 0 08-09-2009 09:43 AM
GE Refrigerator not cooling gt2303a Refrigerator & Freezer Repair 0 03-07-2008 01:48 PM
