We have a Samsung RS2530BBP refrigerator with an ice maker that has stopped functioning. The water dispenser works, if you put ice in the ice bin it will dispense ice, but if you push the reset button the water valve does not open nor does the tray rotate. I first replaced the ice maker module with no results. Pushed the reset button and nothing happens. I then replaced the main power circuit board thinking that power was not coming to the ice maker. Again nothing happens. I push the reset button and the water valve doesn't open nor does the ice tray cycle. Any suggestions?
