phil.woodell@verizon.net
#1 Posted : Saturday, August 4, 2012 1:50:39 PM(UTC)
Due to a power surge i had to replace my ADCII with a ADCIV, this included replacing the damper motor switch wiring from 2 to 1 connection when installing the new wiring harness. Now the damper motor constantly cycles open - close, etc. I know this will cause problems with the damper motor, please help...
Read more: http://forum.appliancepartspros...cling.html#ixzz22cHFHMmL
http://forum.appliancepartspros.com
The parts I replaced are the following
ADC IV Kit 5303918476 included in kit are part #'s
242011001 - ADC IV
241735702 - Control box wiring harness
5303950257 - Instruction sheet
Please help I haven't been able to use my fridge for 3 weeks.
#2 Posted : Wednesday, August 8, 2012 2:56:32 PM(UTC)
The switch is connected properly to the connector that is farthest from the damper door motor.
#3 Posted : Friday, August 10, 2012 10:47:42 AM(UTC)
Can someone please help I have been waiting for two weeks to get a reply my original post had one reply which was a question, i answered it and got no replies since 7/29, either the control board is bad, the temperature gauge isn't working or the damper motor is bad it just continously opens and closes, i have taken it apart 3 times now sometimes the defroster in the freezer quits working and the evaporator freezes up again. until i unplug it
#4 Posted : Friday, August 10, 2012 2:05:10 PM(UTC)
Now the fridge light even quit!!!:confused:
