| » Kitchen Aid Superba Ice Clumping |
Model Number: KSRB25FHSS Brand: Kitchen Aid Age: More than 10 years
Ice is clumping in the bin. I think the picture will describe the issue better than me trying to explain it.
Thanks, RRR Ads By Google Related Models |
The first thing you may want to do is measure the temperature inside the freezer using a special refrigerator thermometer. Post the results.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
If this is correct, what was with the ice cubes while the temperature reading was zero? Gene.
__________________
I believe I may have misread the first reading. From what I can tell when it is 0 degrees the ice is intermittently good and bad. When I check and catch a ice cycle sometimes it's good sometimes it's like the first picture. Other times I just find the large clumps in the bin. I just caught an ice cycle that was good. I attached a picture (somewhat out of focus). I watched them fall into the bin with no issues. I did have to remove a clump out of the way so the arm could move back up to make the ice drop.
There is a water level adjustment screw on the right side of the ice maker control module. Very likely you have to remove the ice maker head cover to gain the access to it. Turn the screw CW for about 180°. It should decrease amount of water coming into the ice maker.
If it would not fix the problem, replace the water inlet valve on the back of the refrigerator. - The water inlet valve Part number: W10408179 Gene.
__________________
Watch a harvest cycle and wait until it fills. When it fills make sure it's not dripping from the back of the ice maker itself. If it drips from the back of the ice maker remove the I/M and check the coating on the mold. If it's flaking or peeling off it may need a new ice maker, the peeling coating will actually cause water to "wick" out of the Ice maker. I see this misdiagnosed for a water valve more often than not.
Hope this helps. |
| Display Modes | |
| Kitchen Aid Superba - Sometimes won't drain | benfinkel | Dishwasher Repair | 0 | 01-10-2012 10:10 PM |
| Kitchen Aid Superba Gas Oven | eyendall | Oven Repair (including Ranges and Cooktops) | 1 | 07-12-2011 01:44 PM |
| kitchen aid superba | mrcletus | Dishwasher Repair | 0 | 08-24-2009 12:56 PM |
| Kitchen Aid Superba | sandbarsun | Oven Repair (including Ranges and Cooktops) | 1 | 08-11-2009 01:59 PM |
| Kitchen Aid Superba | Casey9 | Washer Repair | 0 | 08-04-2008 09:28 AM |
