| » Maytag Ice/Water Dispenser Stopped Working |
Model Number: MFI2568AES Brand: Maytag Age: 1 - 5 years
I have a Maytag French Door Refrigerator with Bottom Freezer Model MFI2568AES with an Ice/Water dispenser in the door. The refrigerator stopped dispensing water and ice. The front panel has power and the light is on. If I unplug the refrigerator and plug it back in water and ice will dispense once, then stop again. Any suggestions would be appreciated. Thank you.
Sounds like the problem is a bad dispenser control board.
- The control board Part number: 67006294 Here are the breakdown diagrams and Replacement parts for Maytag MFI2568AES REF - BOTTOM MOUNTS | AppliancePartsPros.com Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
Quote:
__________________
Hello Gene, I have similar problem. I disconnected the Cavity motor and mullion connector from the LV board (J3). It has a blue/white, Blue/red, Red/BLK. The ice flap does not open and close once I disconnected the connector. Problem is that the water and ice doesn't work and the LV Board would flash on and off. Basically nuts. I when into the program mode and turned on the cavity motor from off and it dispenses water but then I try the ice and it wants to...but goes back to the ice flap open and closes. I went back into the Program setting and the cavity motor resets to off. I read that others have replaced the HV board. Others the LV board. Once I reconnect to J3 it starts to flash numbers on the display and ice flaps open and close. I also talked to maytag and they say that no recall on this model. I believe so but they deny. Any suggestions?
What is the complete model number of the refrigerator?
__________________
Per the Maytag Service bulletin (attached to the post) the correction is to replace the HV control board.
- The HV control board kit Part number: 12920710 Gene.
__________________
Hello Gene, I checked the HV board and found two CD282 Aluminum Electrolytic capacitor popped. I ordered the capacitors and will soldier them in and give it a try. If no go... then I will order a new board. I will keep you posted. Thanks again.
Artsram |
| Display Modes | |
| Water dispenser stopped working | Sandiinflorida | Refrigerator & Freezer Repair | 5 | 10-05-2011 02:58 PM |
| Water dispenser stopped working | chouseal | Refrigerator & Freezer Repair | 0 | 03-12-2011 07:44 PM |
| water dispenser stopped working | barbjustin | Refrigerator & Freezer Repair | 0 | 04-08-2010 07:55 AM |
| GE - Water Dispenser Stopped Working | toofast | Refrigerator & Freezer Repair | 3 | 12-16-2009 06:20 AM |
| Water Dispenser Stopped Working | TCaruthers | Refrigerator & Freezer Repair | 0 | 11-09-2009 04:55 AM |
