Discuss
KitchenAid compressor running, no cold
 in
Refrigerator & Freezer Repair
I have a 5.5 year old Kitchen Aid kbfa25erbl01. Overnight it has stopped working. The fridge and the trays contained
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » KitchenAid compressor running, no cold
  #1 (permalink)
Old 07-29-2012, 02:08 PM
Junior Member
bagadonitz is on a distinguished road
Default KitchenAid compressor running, no cold
Model Number: kbfa25erbl01   Brand: Kitchen Aid   Age: 5 - 10 years
The fridge and the trays contained no water.
The condenser coil on the bottom was severely clogged with dust. Now spotless with compressed air and vacuuming.
The evaporator coil is not iced up. There is zero frost building up on it when the fridge is run. None of the lines coming from the compressor or going into or coming out of the evaporator are particularly cold, even after a few hours running.
The condensor fan is running. The tube coming from the evaporator tray down into the condensor tray doesn't appear to be plugged.
The compressor runs very quietly and smoothly but I can tell it is definitely on. There is 120 volts going to the starter relay when the fridge is on. It is warm to the touch but I wouldn't describe it as being hot either but then I don't have any sense of what the baseline feels like either.
With the starter relay removed there is no continuity between any of the three prongs for the relay and the ground or freshly scratched paint of the compressor.
The pins on this have one on top, two on bottom.
Between the two bottom pins, 9.2 ohms.
Between the top and the left pin, 4.2 ohms.
Between the top and the right pin, 5.1 ohms.
Based on that it seems the compressor is fine.
Based on the fact that it starts the compressor it seems the relay is fine.
What is the most likely issue here? Is it possible that there is something wrong with the compressor or relay or is this a refrigerant issue?
If it is a refrigerant issue, what can I expect it is going to cost to have that resolved?
If it is a faulty compressor and not a refrigerant issue, am I better off cutting my losses and purchasing new? Parts seem to be expensive and a compressor replacement doesn't seem like a DIY job.
Thank you for your time.
Ads By Google
Related Models
Whirlpool KBFA25ERBL01 Refrigerator
Whirlpool KBFA25ERSS00 Refrigerator
Whirlpool KBFA25ERSS01 Refrigerator
Whirlpool KBFA25ERWH00 Refrigerator
Whirlpool KBFA25ERWH01 Refrigerator
Whirlpool KBFC42FSS00 42" Bottom Mount Built in Refrigerator
Whirlpool KBFC42FTS00 42" Bottom Mount Built in Refrigerator
Whirlpool KBFC42FTS02 42" Bottom Mount Built in Refrigerator
Whirlpool KBFL25ETBL00 Refrigerator
Whirlpool KBFL25ETSS00 Refrigerator
Whirlpool KBFL25ETWH00 Refrigerator
Whirlpool KBFO42FSX00 42" Bottom Mount Built in Refrigerator
Whirlpool KBFO42FTX00 42" Bottom Mount Built in Refrigerator
Whirlpool KBFO42FTX02 42" Bottom Mount Built in Refrigerator
Whirlpool KBFS20ETBL00 Refrigerator
Whirlpool KBFS20ETSS00 Refrigerator
Whirlpool KBFS20ETWH00 Refrigerator
Whirlpool KBFS25ETBL00 Refrigerator
Whirlpool KBFS25ETSS00 Refrigerator
Whirlpool KBFS25ETWH00 Refrigerator
Whirlpool KBGN274LSS0 Built - in Grille 27"
Whirlpool KBGN274PSS0 Built - in Grille 27"
Whirlpool KBGN274SSS0 Built - in Grille 27"
Whirlpool KBGN292LSS0 Built - in Grille with Side Burners 39"
Whirlpool KBGN292PSS0 Built - in Grille with Side Burners 39"
Whirlpool KBGN364LSS0 Built - in Grille 36"
Whirlpool KBGN364PSS0 Built - in Grille 36"
Whirlpool KBGN364SSS0 Built - in Grille 36"
Whirlpool KBGS274LSS0 Built - in Grille 27"
Whirlpool KBGS274PSS0 Built - in Grille 27"
Whirlpool KBGS274SSS0 Built - in Grille 27"
Whirlpool KBGS292LSS0 Built - in Grille with Side Burners 39"
Whirlpool KBGS292PSS0 Built - in Grille with Side Burners 39"
Whirlpool KBGS364LSS0 Built - in Grille 36"
Whirlpool KBGS364PSS0 Built - in Grille 36"
Whirlpool KBGS364SSS0 Built - in Grille 36"
Whirlpool KBHC109JBL0
Whirlpool KBHC109JBL03 30" Built - in Microwave
Whirlpool KBHC109JBL04 30" Built - in Microwave
Whirlpool KBHC109JBL05 30" Built - in Microwave
Whirlpool KBHC109JBT0
Whirlpool KBHC109JBT03 30" Built - in Microwave
Whirlpool KBHC109JSS0
Whirlpool KBHC109JSS03 30" Built - in Microwave
Whirlpool KBHC109JSS04 30" Built - in Microwave
Whirlpool KBHC109JSS05 30" Built - in Microwave
Whirlpool KBHC109JWH0
Whirlpool KBHC109JWH03 30" Built - in Microwave
Whirlpool KBHC109JWH05 30" Built - in Microwave
Whirlpool KBHC179JBL0
Whirlpool KBHC179JBL03 27" Built - in Microwave
Whirlpool KBHC179JBL04 27" Built - in Microwave
Whirlpool KBHC179JBL05 27" Built - in Microwave
Whirlpool KBHC179JBT0
Whirlpool KBHC179JSS0
Whirlpool KBHC179JSS03 27" Built - in Microwave
Whirlpool KBHC179JSS04 27" Built - in Microwave
Whirlpool KBHC179JSS05 27" Built - in Microwave
Whirlpool KBHC179JWH0
Whirlpool KBHC179JWH03 27" Built - in Microwave
Whirlpool KBHS109SSS00 30" Built - in Microwave
Whirlpool KBHS109SSS01 30" Built - in Microwave
Whirlpool KBHS179SSS00 27" Built - in Microwave
Whirlpool KBHS179SSS01 27" Built - in Microwave
Whirlpool KBHV109PMT00 30" Built - in Microwave
Whirlpool KBHV109PMT01 30" Built - in Microwave
Whirlpool KBHV109PSS00 30" Built - in Microwave
Whirlpool KBHV109PSS01 30" Built - in Microwave
Maytag KBLA20ELSS0  Ref - Bottom Mounts
Whirlpool KBLA20ELSS00 Refrigerator
Whirlpool KBLA20ELSS01 Refrigerator
Whirlpool KBLA20EMSS00 Refrigerator
Whirlpool KBLA20ERSS00 Refrigerator
Whirlpool KBLA20ERSS01 Refrigerator
Whirlpool KBLA22ERSS00 Refrigerator
Whirlpool KBLA22ERSS01 Refrigerator
Whirlpool KBLA22ERWH00 Refrigerator
Whirlpool KBLA22KLSS00 Refrigerator
Whirlpool KBLA22KLSS01 Refrigerator
Whirlpool KBLA22KMSS00 Refrigerator
Whirlpool KBLA22KRSS00 Refrigerator
Whirlpool KBLA22KRSS01 Refrigerator
Whirlpool KBLC36FKB00
Whirlpool KBLC36FKB01
Whirlpool KBLC36FKB02 36" Bottom Mount Built in Refrigerator
Whirlpool KBLC36FKS00
Whirlpool KBLC36FKS01
Whirlpool KBLC36FKS02 36" Bottom Mount Built in Refrigerator
Whirlpool KBLC36FMS00 36" Bottom Mount Built in Refrigerator
Whirlpool KBLC36FMS01 36" Bottom Mount Built in Refrigerator
Whirlpool KBLC36FMS02 36" Bottom Mount Built in Refrigerator
Whirlpool KBLC36FTS00 36" Bottom Mount Built in Refrigerator
Whirlpool KBLC36FTS02 36" Bottom Mount Built in Refrigerator
Whirlpool KBLC36MHB01
Whirlpool KBLC36MHS00
Whirlpool KBLC36MHS01
Whirlpool KBLC36MHT01
Whirlpool KBLC36MHW01
Whirlpool KBLO36FMX00 36" Bottom Mount Built in Refrigerator
Whirlpool KBLO36FMX01 36" Bottom Mount Built in Refrigerator
Whirlpool KBLO36FMX02 36" Bottom Mount Built in Refrigerator
Whirlpool KBLO36FTX00 36" Bottom Mount Built in Refrigerator
Whirlpool KBLO36FTX02 36" Bottom Mount Built in Refrigerator
Whirlpool KBLP36FKS00
Whirlpool KBLP36FKS02 36" Bottom Mount Built in Refrigerator
Whirlpool KBLP36FMS00 36" Bottom Mount Built in Refrigerator
Whirlpool KBLP36FMS02 36" Bottom Mount Built in Refrigerator
Whirlpool KBLP36MHB00
Whirlpool KBLP36MHB01
Whirlpool KBLP36MHS00
Whirlpool KBLP36MHS01
Whirlpool KBLP36MHT00
Whirlpool KBLP36MHT01
Whirlpool KBLP36MHW00
Whirlpool KBLP36MHW01
Whirlpool KBLS19KTSS00 Refrigerator
Whirlpool KBLS20ETSS00 Refrigerator
Whirlpool KBLS22ETSS00 Refrigerator
Whirlpool KBLS22ETSS11 Refrigerator
Whirlpool KBLS22KTSS00 Refrigerator
  #2 (permalink)
Old 07-29-2012, 02:30 PM
ApplianceJunk's Avatar
Senior Expert
APP Volunteer
ApplianceJunk is on a distinguished road
Default
Sounds like the refrigerant has leaked out or a faulty compressor.
Neither one is a DIY type of job and my not be worth the cost of repair.
__________________
ApplianceJunk.com ~ DIY Appliance Repair Forum
  #3 (permalink)
Old 07-31-2012, 11:00 AM
Junior Member
J fenner is on a distinguished road
Lightbulb
I had the same problem with my side by side, to make sure it wasnt a compressor issue I went to M A r c o n E and picked up a $3.00 piercing valve, put it on the charge port, vacuumed it down and gradually charged it to a 5# running charge on the 134a scale getting below 0 temps in the freezer and 40* and lower in the refer side, I am having defrost issues and have to tackle that but need to empty the fridge of groceries first. Keeping the rugrats from standing at the open doors helps.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
freeze cold but compressor never stop running Nomad Terry Refrigerator & Freezer Repair 5 11-10-2011 01:35 AM
Ffrige and freezer cold - compressor still running broman Refrigerator & Freezer Repair 0 08-25-2011 08:21 PM
compressor not running? drmax Refrigerator & Freezer Repair 4 07-21-2011 01:27 PM
Freezer running extra cold and frig running warm elora97 Refrigerator & Freezer Repair 2 05-23-2010 04:51 PM
freezer running non stop, fridge is not running but staying cold galvatron Refrigerator & Freezer Repair 1 10-05-2009 04:17 PM
