Discuss
Help Locating Defroster Components
 in
Refrigerator & Freezer Repair
My freezer was cold and my refrigerator was warm. I unplugged the unit, took apart the interior freezer panels and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Help Locating Defroster Components
  #1 (permalink)
Old 07-27-2012, 08:09 PM
Junior Member
Lampshade is on a distinguished road
Thumbs up Help Locating Defroster Components
Model Number: EET-172PK   Brand: Whirlpool   Age: More than 10 years
My freezer was cold and my refrigerator was warm. I unplugged the unit, took apart the interior freezer panels and my coil was encased in a block of ice. I defrosted it put it back together and the next morning my freezer and refrigerator were both very cold.
I am going to go back in and test the heater, timer and thermostat but I have been unable to find any manuals for this model. It is a top freezer unit.
If someone could help me with the locations of the timer and the thermostat it would help me.
Thank you.
Ads By Google
Related Models
Whirlpool EET121DTWR0
Whirlpool EET121ETWR0
Whirlpool EET122DTWR0
Whirlpool EET131DTWR0
Whirlpool EET131DTWR1
Whirlpool EET131DTWR2
Whirlpool EET131JTWR0
Whirlpool EET131JTWR1
Whirlpool EET132DTWR0
Whirlpool EET132JTWR0
Whirlpool EET133DTWR0
Whirlpool EET133JTWR0
Whirlpool EET134DTWR0
Whirlpool EET134JTWR0
Whirlpool EET141DTWR0
Whirlpool EET141DTWR1
Whirlpool EET141EKWR0
Whirlpool EET141EKWR1
Whirlpool EET141EKWR2
Whirlpool EET141JKWL0
Whirlpool EET141JKWR0
Whirlpool EET141JKWR1
Whirlpool EET141PKWR0
Whirlpool EET142EKWR0
Whirlpool EET142JKWR0
Whirlpool EET143EKWR0
Whirlpool EET143EKWR1
Whirlpool EET143JKWR0
Whirlpool EET143JKWR1
Whirlpool EET151DTWR0
Whirlpool EET151DTWR1
Whirlpool EET151ETWR0
Whirlpool EET151ETWR1
Whirlpool EET151ETWR2
Whirlpool EET151JMWR0
Whirlpool EET151JMWR1
Whirlpool EET151JMWR2
Whirlpool EET151JMWR3
Whirlpool EET151JMWR4
Whirlpool EET151JMWR5
Whirlpool EET151JTWR0
Whirlpool EET151JTWR1
Whirlpool EET151JTWR2
Whirlpool EET151JTWR3
Whirlpool EET151PKWR0
Whirlpool EET151PKWR2
Whirlpool EET151PKWR3
Whirlpool EET152DTWR0
Whirlpool EET152JMWR0
Whirlpool EET152JMWR1
Whirlpool EET152JTWR0
Whirlpool EET152JTWR1
Whirlpool EET153DTWR0
Whirlpool EET153JTWR0
Whirlpool EET153JTWR1
Whirlpool EET171EKWR0
Whirlpool EET171EKWR1
Whirlpool EET171EKWR2
Whirlpool EET171EKWR4
Whirlpool EET171ETWR0
Whirlpool EET171ETWR1
Whirlpool EET171HKWR0
Whirlpool EET171HKWR1
Whirlpool EET171MKWR0
Whirlpool EET171MKWR1
Whirlpool EET171MKWR2
Whirlpool EET171MMWR0
Whirlpool EET171MMWR1
Whirlpool EET171MMWR3
Whirlpool EET171NKWR0
Whirlpool EET171NKWR2
Whirlpool EET171PKWR0
Whirlpool EET171PKWR1
Whirlpool EET171PKWR2
Whirlpool EET171PKWR3
Whirlpool EET171PKWR4
Whirlpool EET171PKWR5
Whirlpool EET171SKWR0
Whirlpool EET171SKWR1
Whirlpool EET171VKWR0
Whirlpool EET171VKWR2
Whirlpool EET172EKWR0
Whirlpool EET172ETWR0
Whirlpool EET172HKWR0
Whirlpool EET172MKWR0
Whirlpool EET172MMWR0
Whirlpool EET172PKWR0
Whirlpool EET172PKWR1
Whirlpool EET172SKWR0
Whirlpool EET172VKWR0
Whirlpool EET173EKWR0
Whirlpool EET173EKWR1
Whirlpool EET173ETWR0
Whirlpool EET173PKWR0
Whirlpool EET173PKWR1
Whirlpool EET191EKWR0
Whirlpool EET201EKWR0
Whirlpool EET201EKWR2
Whirlpool EET201MKWR0
Whirlpool EET201MKWR1
Whirlpool EET201MKWR3
Whirlpool EET201MKWR4
Whirlpool EET201MMWR0
Whirlpool EET201MMWR1
Whirlpool EET201MMWR2
Whirlpool EET201PKWR0
Whirlpool EET201PKWR1
Whirlpool EET201PKWR3
Whirlpool EET201PKWR4
Whirlpool EET201VKWR0
Whirlpool EET201VKWR1
Whirlpool EET201VKWR2
Whirlpool EET201ZKWR0
Whirlpool EET202EKWR0
Whirlpool EET202MKWR0
Whirlpool EET202MMWR0
Whirlpool EET202PKWR1
Whirlpool EET202PKWR2
Whirlpool EET202VKWR0
Whirlpool EET203EKWR0
  #2 (permalink)
Old 07-28-2012, 04:33 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
Here is what comes up when I search AppliancePartsPros for your model number.
Replacement parts for EET-172PK models | AppliancePartsPros.com
Both units are probably basically the same.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
Manually force a defrost cycle by turning the defrost timer cam (Item 53 in Section 5) till the fans and compressor turn off.
There is usually a hole in the cover to let you do this without taking anything apart. Looks like on your unit you may have to pop out the plug (Item 44 in Section 5)
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 37 in Section 7) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 43 in Section 7) (clipped onto the defrost coils) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
__________________
  #3 (permalink)
Old 07-28-2012, 06:49 AM
Junior Member
Default how do I get to the timer?
I had part #6 removed and part #7 is a large pice of styrofoam.Will I find it below #7?
  #4 (permalink)
Old 07-28-2012, 01:19 PM
Junior Member
Default I see
I found it. It is behind the plastic cover where the temp. control knob is.
  #5 (permalink)
Old 07-28-2012, 01:48 PM
Junior Member
Default Success
I removed the interior panels from the freezer section. The coil was already icing up . I rotated the timer with a screwdriver and the fan and compressor turned off. The heater turned on. I would caution anyone who has never done this before: the heater is VERY HOT.
I rotated the timer to turn everything back on and now it is time to order the new timer.
This forum saved me a lot of money. Thanks so much.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Need help locating Defrost Timer Sherry T Refrigerator & Freezer Repair 1 05-10-2011 02:44 AM
Locating Fuses Vince Clancy Dryer Repair 1 01-13-2010 07:25 AM
Locating Thermal Fuses Jeff AH Dryer Repair 0 04-23-2009 05:36 PM
Need help locating thermostat Hilusi Microwave Repair 1 01-16-2008 04:32 PM
