| » Cooling Problems |
Model Number: DBC2760BLS Brand: -other- Age: 1 - 5 years
Hi there,
I'm having problems determining the cause for my Wine Cooler to not cool properly. When plugged in... all the fans are running. The temperature drops on the very bottom shelf of the fridge, but nowhere else. The compressor runs HOT. I put a mulit-meter on the relay switch prongs and the readings I got where 5 ohms, and 6.9 ohms. The condensor coils are clean... Any suggestions.... I'm wondering if it's the compressor... This is a Danby DBC2760BLS Ads By Google Related Models |
Seems like you have a bad compressor. I assume there is no evaporator fan, just a condensing fan. You can check inside the fridg for a vent and fan. If so, you might have an evaporator fan motor running backwards and not blowing any air.
__________________
There are actually 2 evaporator fans...
if you search for DG1-30, which is the compressor, you will be able to find a schematic. This is a dual climate wine cooler. I don't feel any air blowing when the fans are running... what are some possible causes for a fan to run backward, and would this be a reason for the compressor to heat up? Last edited by ronnysharma : 07-29-2012 at 02:59 PM. |
The fan motors are shaded pole,induction motors. Sometimes they get poled backwards from a power surge that opens a bias winding. You will need to get to each motor and check.
__________________
| Display Modes | |
| Frigidaire side-by-side cooling problems | ChrisTN | Refrigerator & Freezer Repair | 4 | 02-12-2012 08:51 AM |
| Hotpoint refrigerator stopped cooling - possible problems? | blmer | Refrigerator & Freezer Repair | 5 | 01-06-2012 09:43 PM |
| Cooling problems - Defrost Heater | mata2mata | Refrigerator & Freezer Repair | 0 | 01-13-2010 01:49 PM |
| GE Side by Side Bad Cooling Problems | POKLET | Refrigerator & Freezer Repair | 1 | 07-06-2009 06:13 AM |
| Cooling problems with Amana side-by-side | tsears | Forum Announcements | 1 | 01-05-2009 05:54 PM |
