Ice Maker is not getting water to it. Instead of water going into ice maker it is coming out the water dispenser on the front of the door. We changed the filter thinking maybe that would work and instead of a little water coming out of the door a lot comes out now and still no water in the ice maker. It does go through the cycle it just doesn't put water in the ice maker.
Groups: APP Team
Hi. Most likely you need to replace the diod kit by the water valve. See the attached file. Thank you. Simon.
