The Ice Maker, model WR30X0289, connected to a GE Monogram 42" built-in, model ZISW42EMB, is only completed one cycle of making ice and then shutting down. To start another cycle, I disconnect/reconnect the plug-in connector from the ice maker to the freezer compartment. Water does flow and I replaced the WATER VALVE ASM WR57X10051 about one year ago.
Is there some tests to run or does the ice maker need replacement?
thanks a bunch.
dave
