| » No Evap Fans, No Compressor |
Model Number: 596.50399001 Brand: Kenmore Age: More than 10 years
Hi All. I sure hope someone can help me with this...and a GREAT BIG preemptive THANK YOU to any who can!
Kenmore side-by-side. Came home the other day from a trip, water all over the floor, frig and freezer warm. I removed the back panel and the compressor isnt running, but the compressor fan is. The evaporator (interior) fans are not running either, but light is on. The compressor clicks, hums a little, then clicks off within a few seconds....this repeats every minute or two. The top of the compressor isnt hot. I replaced the start relay on the compressor (part from a local parts dealer) to no avail. m I looking at a bad compressor, bad timer or something else? The timer is 'ticking' and I have advanced it to run... not sure if that is it or not. So to recap: Compressor tries, but doesnt start. At no time are the / is the evap fans running. The compressor fan is running. Any tips? Thanks so much in advance!! Mal. Ads By Google Related Models |
Best to use a meter on this. If the compressor is not hot and it fails to start with the recomended start device, and you wired it properly, you probably have a bad compressor.
__________________
Quote:
Thank you very much for you reply! After reading it I decided to plug the refrig in from 20 mins. Yes, the compressor is very warm on top (not too ho to touch, but very warm). I am sure if I left it plugged in longer it would get much hotter. What bad component would that point to? Update: Although I replaced the relay, I didnt notice that the relay and overload are two parts. Pulled the overload, held it firmly in the middle and it rattles when I shake it. Again, the compressor tries to start, then kicks off after a few seconds. Is the overload working right by shutting it off, or is it prematurely kicking it off? Last edited by Malcrast : 07-18-2012 at 06:48 AM. |
Quote:
Well I hooked up a 3-in-1 and the unit is running and getting cold. But when I hook everything else up original without the 3-in-1, same thing. What could this indicate? |
It indicates you have shorted turns in the compressor start winding and, or mechanical problems in the compressor.
I would NEVER use a 3 n 1 on a modern R134A refigerant compressor, particularly if you have a damaged compressor, will result in compressor failure without warning. These devices provide no thermal overload, or power surge protection and have caused house fires.
__________________
If you shake the relay and little flecks of metal comes out, it means the silicon disk inside the relay has shattered. Use the correct relay to replace it. I do not recommend 3in1's as well. If the proper relay does not work then i would say that you have an issue in your compressor.
| Display Modes | |
| Fridge fails to cool/evap and cooling fans work | flespu | Refrigerator & Freezer Repair | 9 | 01-27-2012 07:24 PM |
| Do the evap.fans run all the time? | ryan123 | Refrigerator & Freezer Repair | 0 | 04-23-2011 07:48 AM |
| ADC replaced TC works no fans, no compressor | maxcichon | Refrigerator & Freezer Repair | 2 | 10-11-2010 09:29 AM |
| Lights On, Fans Running, No Compressor.. | jstutz101 | Refrigerator & Freezer Repair | 3 | 10-13-2009 05:41 PM |
| Compressor and fans not working | bobgehrman | Refrigerator & Freezer Repair | 2 | 04-25-2009 09:35 AM |
