I recently replaced the Evaporator heater the old one was open, I diconnected wires to thermostat and checked it also there was continuity thru it, the fan had been running earlier but somehow not sure if i got all the wires in the right place,hmm! should have paid more attention. I have (2) wires yellow and brown, when I measure across them I have @ 77VAC. I am quite cerain this is a 115VAC Fan. When wires are connected Fan doesn't operate. I hooked suicide cord to fan outside of fridge it runs as smooth as silk, I measured resistance across fan @ 33 ohms. So I am assuming fan is good, since it was working prior to me dismantling everthing. I sure could use advice here.
