Discuss
freeser ok but refrig varies from 40 to 52 degrees
 in
Refrigerator & Freezer Repair
hello my ge side by side refrigator varies in temoerature form 41 degrees to 51 degrees freezer sde appears to
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » freeser ok but refrig varies from 40 to 52 degrees
  #1 (permalink)
Old 07-15-2012, 03:33 PM
Junior Member
narocroc is on a distinguished road
Default freeser ok but refrig varies from 40 to 52 degrees
Brand: GE   Age: 5 - 10 years
hello my ge side by side refrigator varies in temoerature form 41 degrees to 51 degrees freezer sde appears to be ok the model no is ess25gmbb thanks for any help! narocroc
Ads By Google
  #2 (permalink)
Old 07-15-2012, 07:39 PM
Member
dnlow is on a distinguished road
Default
Have you checked to see if the damper is working correctly. It is a door that allows air from the freezer compartment into the fresh food side. Your description of the problem sounds like this is a good place to start.
  #3 (permalink)
Old 07-16-2012, 01:47 AM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Also, measure the freezer temperature and post.
__________________
  #4 (permalink)
Old 07-17-2012, 03:44 PM
Junior Member
Default
Quote:
freezer temp is 15 to 20 degrees i know it should be -5 or so for freezer and 40 for refrig .per other posts for this pbm it could be the defrost thermostat /timer or defrost heater model no is ess25xgmb >I see the parts catolog and the part no. but no breakdown as to how to open the inside panel of freezer and access the parts..thanks narocroc
  #5 (permalink)
Old 07-18-2012, 02:33 AM
Senior Expert
APP Volunteer
Default
Unplug fridg. pull up a chair and remove all the screws from the bottom panel, tilt the panel up and check the evaporator coils, if covered with total, heavy frost, remove panel and defrost with hair dryer, post results.
__________________
  #6 (permalink)
Old 07-23-2012, 03:26 PM
Junior Member
Default
damper assy opens just fine .the refrig was mover to the garage on my arrival removed all access comers and powered on refrigerator,observing the frezer coils occasionally,(every 2 or three minutes) they start to frost up from bottom going towards top .the motor opens the door to the refrig ok . the fan over the coils in freezer runs ok.the defrost limiter thermostat does not have a adjustment screw on it so i assume the mother board controls that. I know Gene has posted a good review of defrost problems (has helped me on a previus pbm with this beast) .the box will be plugged back in tonight.i will arrive onsite on tues 1200 noon pst to check continuity on defrost limitor nd on heater assy at that time,thanks again for all your help and patience,respectfully narocroc.the model no is ess25xgmb approx 13 years old,thanks narocroc
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer -4 degrees and refrigerator 48 degrees FDAR Refrigerator & Freezer Repair 0 11-19-2011 03:58 PM
Freezer @ 15 degrees refrigerator @37 degrees mfoxgrover Refrigerator & Freezer Repair 2 10-05-2010 02:54 PM
Freezer temp intermittantly varies from 5 to 35 degrees jrvetter Refrigerator & Freezer Repair 0 12-19-2009 09:21 AM
Will Unplugging freeser cause it to stop working grantsork Refrigerator & Freezer Repair 1 11-09-2009 03:44 AM
oven temperature varies 100 degrees bigal_1234@msn.com Oven Repair (including Ranges and Cooktops) 2 01-31-2008 03:09 PM
