Discuss
Maytag Evaporator fan shutting off. Heating front of fridge
 in
Refrigerator & Freezer Repair
My Maytag fridge gets really hot on the front middle panel. I do know that the fan "not" running is
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Maytag Evaporator fan shutting off. Heating front of fridge
  #1 (permalink)
Old 09-17-2009, 05:32 AM
Junior Member
sbru is on a distinguished road
Default Maytag Evaporator fan shutting off. Heating front of fridge
Model Number: MZD2766GEB   Brand: Maytag   Age: 5 - 10 years
My Maytag fridge gets really hot on the front middle panel. I do know that the fan "not" running is causing it. But while the fridge is on I spin the stopped fan and it keeps going for a long while, maybe hours. Then later on I find it stopped again and the fridge is hot on the front again.
Is it simply a fan motor or something else maybe?
Related Models
Maytag MZD2766GEB REF - SXS/I&W
Maytag MZD2766GEQ REF - SXS/I&W
Maytag MZD2766GES REF - SXS/I&W
Maytag MZD2766GEW REF - SXS/I&W
Maytag MZD2768GEB REF - SXS/I&W
Maytag MZD2768GEQ REF - SXS/I&W
Maytag MZD2768GEW REF - SXS/I&W
Whirlpool N N ELECTRIC RANGES AND OVENS
Norge N1100PAW RANGE- F/S STD GAS
Norge N1100PRA RANGE- F/S STD GAS
Norge N1100PRA-L RANGE-F/S CONT CLEAN GAS
Norge N1100PRW RANGE- F/S STD GAS
Norge N1100PRW-L RANGE-F/S CONT CLEAN GAS
Norge N1500PRA RANGE- F/S STD ELE
Norge N1500PRW RANGE- F/S STD ELE
Norge N31100PAA RANGE- F/S STD GAS
Norge N31100PAW RANGE- F/S STD GAS
Norge N3110KRA RANGE- F/S STD GAS
Norge N3110KRW RANGE- F/S STD GAS
Norge N3110PPA RANGE- F/S STD GAS
Norge N3110PPW RANGE- F/S STD GAS
Norge N3110PRA RANGE- F/S STD GAS
Norge N3110PRW RANGE- F/S STD GAS
Norge N31111XAA RANGE- F/S STD GAS
Norge N31111XAW RANGE- F/S STD GAS
Norge N31115WAV RANGE- F/S STD GAS
Norge N31115XAA RANGE- F/S STD GAS
Norge N31115XAW RANGE- F/S STD GAS
Norge N3120SPA RANGE- F/S STD GAS
Norge N3120SPN RANGE- F/S STD GAS
Norge N3120SPW RANGE- F/S STD GAS
Norge N3120SRA RANGE- F/S STD GAS
Norge N3120SRW RANGE- F/S STD GAS
Norge N3121XPA RANGE- F/S STD GAS
Norge N3121XPW RANGE- F/S STD GAS
Norge N3121XRA RANGE- F/S STD GAS
Norge N3121XRW RANGE- F/S STD GAS
Norge N3121XTA RANGE- F/S STD GAS
Norge N3121XTW RANGE- F/S STD GAS
Norge N3137XRA RANGE- F/S STD GAS
Norge N3137XRW RANGE- F/S STD GAS
Roper N3157*0 Ranges, Electric*
Roper N3157*1 Ranges, Electric*
Roper N3157W0 Ranges, Electric*
Roper N3157W1 Ranges, Electric*
Norge N3177VUV RANGE- F/S STD GAS
Norge N3177XRA RANGE- F/S STD GAS
Norge N3177XRW RANGE- F/S STD GAS
Norge N3177XUA RANGE- F/S STD GAS
Norge N3177XUW RANGE- F/S STD GAS
Roper N3257*0 Ranges, Electric*
Roper N3257*1 Ranges, Electric*
Roper N3257W0 Ranges, Electric*
Roper N3257W1 Ranges, Electric*
Roper N3357*0 Ranges, Electric*
Roper N3357W0 Ranges, Electric*
Norge N3422PRA RANGE- S/C F/S GAS
Norge N3422PRW RANGE- S/C F/S GAS
Norge N3438SRA RANGE- S/C F/S GAS
Norge N3438SRW RANGE- S/C F/S GAS
Norge N3438VRV RANGE- S/C F/S GAS
Roper N3457*0 Ranges, Electric*
Roper N3457W0 Ranges, Electric*
Norge N3472SRA RANGE- S/C F/S GAS
Norge N3472SRW RANGE- S/C F/S GAS
Norge N3478VRV RANGE- S/C F/S GAS
Norge N3478VVV RANGE- S/C F/S GAS
Norge N3478XRA RANGE- S/C F/S GAS
Norge N3478XRW RANGE- S/C F/S GAS
Norge N3478XVA RANGE- S/C F/S GAS
Norge N3478XVW RANGE- S/C F/S GAS
Norge N3510KRA RANGE- F/S STD ELE
Norge N3510KRW RANGE- F/S STD ELE
Norge N3510PPA RANGE- F/S STD ELE
Norge N3510PPW RANGE- F/S STD ELE
Norge N3510PRA RANGE- F/S STD ELE
Norge N3510PRW RANGE- F/S STD ELE
Norge N3520SPA RANGE- F/S STD ELE
Norge N3520SPN RANGE- F/S STD ELE
Norge N3520SPW RANGE- F/S STD ELE
Norge N3520SRA RANGE- F/S STD ELE
Norge N3520SRW RANGE- F/S STD ELE
Norge N3521XPA RANGE- F/S STD ELE
Norge N3521XPW RANGE- F/S STD ELE
Norge N3521XRA RANGE- F/S STD ELE
Norge N3521XRW RANGE- F/S STD ELE
Norge N3832XRA RANGE- S/C F/S ELE
Norge N3832XRW RANGE- S/C F/S ELE
Norge N3875XRA RANGE- S/C F/S ELE
Norge N3875XRW RANGE- S/C F/S ELE
Norge N3878VRV RANGE- S/C F/S ELE
Norge N3878VVD RANGE- S/C F/S ELE
Norge N3878VVV RANGE- S/C F/S ELE
Norge N3878XRA RANGE- S/C F/S ELE
Norge N3878XRW RANGE- S/C F/S ELE
Norge N3878XVA RANGE- S/C F/S ELE
Norge N3878XVW RANGE- S/C F/S ELE
Magic Chef N40C-3-X9 MWAVE- CNTRTP / STAND ALONE
Norge N4231WRA RANGE-F/S CONT CLEAN GAS
Norge N4231WRW RANGE-F/S CONT CLEAN GAS
Norge N4251WTA RANGE- F/S STD GAS
Norge N4251WTW RANGE- F/S STD GAS
Roper N9157*0 Ranges, Electric*
Roper N9157*1 Ranges, Electric*
Roper N9157L0 Ranges, Electric*
Roper N9157L1 Ranges, Electric*
Roper N9157X0 Ranges, Electric*
Roper N9257*0 Ranges, Electric*
Roper N9257*1 Ranges, Electric*
Roper N9257*2 Ranges, Electric*
Roper N9257L1 Ranges, Electric*
Roper N9257L2 Ranges, Electric*
Roper N9257X0 Ranges, Electric*
Roper N9257X1 Ranges, Electric*
Roper N9357*0 Ranges, Electric*
Roper N9357*2 ELECTRIC RANGE
Roper N9357*3 Ranges, Electric*
Roper N9357L0 Ranges, Electric*
Roper N9357L2 ELECTRIC RANGE
Roper N9357L3 Ranges, Electric*
  #2 (permalink)
Old 09-17-2009, 05:57 AM
Senior Expert
APP Volunteer
denman is a splendid one to behold
Default
Replacement parts for MAYTAG MZD2766GEB | AppliancePartsPros.com
Yes: The odds are high that that is your only problem. I would replace it.
Also make sure that the condenser coils are clean.
It is a a pain to clean them on this unit with it's jelly roll.
I clean my unit by removing the rear cover and kick plate.
Roll it over to an open door and blow it out with a compressor.
Also have been told a leaf blower works well.
At least it cuts down on some of the dust in the house.
Note that my fridge is directly across from an outside door so I do not have to worry about ripping or scratching the floor so you may not be able to do this depending on your kitchen layout. It is not worth chancing screwing up the floor.
Can also use a vacuum and a brush
Part number: AP4320046
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Kenmore Dryer Shutting Off Prematurely (Yet Heating) kwinant Dryer Repair 3 07-25-2011 11:14 AM
Fridge bangs when shutting off, works fine emgconsulting Refrigerator & Freezer Repair 1 02-10-2010 08:25 AM
Dryer Not Heating / Shutting Off Happyhomemama Dryer Repair 2 01-03-2010 02:36 AM
Fridge shutting off tomok Refrigerator & Freezer Repair 11 05-05-2009 04:38 PM
Maytag shutting off pettiepetersen Dishwasher Repair 3 09-30-2008 06:53 PM
