Model: KSCS25FTMS02 i USE REVERSE OSMOSIS SO NEVER HAVE USED A FILTER. IN THE LAST COUPLE OF MONTHS THE WATER DISPENSER DRIPS. NOW IT DRIPS MORE SO WE PUT A GLASS UNDER IT INSTEAD OF EMPTYING THE TRAY SO OFTEN HELP!!!!:o
Semper Fi
Sounds like you need a new valve. Part number: AP3886069
Click on the picture for more info on it and a Q&A. If you have a shut off valve in the water line to the valve check that it is wide open. Many valves actually use the water pressure to help with sealing the valve. |
THIS FORUM IS DEAD!!!!!!! |
