Discuss
Water in bottom of freezer
 in
Refrigerator & Freezer Repair
I have an ice build up in the bottom of the freezer and the drain tray is frozen also. I
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Water in bottom of freezer
  #1 (permalink)
Old 07-11-2012, 06:01 PM
Junior Member
hyperactive is on a distinguished road
Default Water in bottom of freezer
Model Number: MSD2464GE   Brand: Maytag   Age: 5 - 10 years
I have an ice build up in the bottom of the freezer and the drain tray is frozen also. I think that the heater may be bad I don't want to take this apart twice can someone tell me if that heater is for the tray and how do I test it.
Ads By Google
Related Models
Maytag MSD2543ARA Ref - SXS/I&W
Maytag MSD2543ARW Ref - SXS/I&W
Maytag MSD2554ARA Ref - SXS/I&W
Maytag MSD2554ARW Ref - SXS/I&W
Maytag MSD2554DRA Ref - SXS/I&W
Maytag MSD2554DRW Ref - SXS/I&W
Maytag MSD2554FRA Ref - SXS/I&W
Maytag MSD2554FRW Ref - SXS/I&W
Maytag MSD2555DRA Ref - SXS/I&W
Maytag MSD2555DRW Ref - SXS/I&W
Maytag MSD2556AEA Ref - SXS/I&W
Maytag MSD2556AEB Ref - SXS/I&W
Maytag MSD2556AEW Ref - SXS/I&W
Maytag MSD2641KEB Ref - SXS/I&W
Maytag MSD2641KES Ref - SXS/I&W
Maytag MSD2641KEU Ref - SXS/I&W
Maytag MSD2641KEW Ref - SXS/I&W
Maytag MSD264RHEB Ref - SXS/I&W
Maytag MSD264RHEQ Ref - SXS/I&W
Maytag MSD264RHES Ref - SXS/I&W
Maytag MSD264RHEW Ref - SXS/I&W
Maytag MSD2650HEB Ref - SXS/I&W
Maytag MSD2650HEQ Ref - SXS/I&W
Maytag MSD2650HES Ref - SXS/I&W
Maytag MSD2650HEW Ref - SXS/I&W
Maytag MSD2650KES Ref - SXS/I&W
Maytag MSD2650KEU Ref - SXS/I&W
Maytag MSD2651HEB Ref - SXS/I&W
Maytag MSD2651HEQ Ref - SXS/I&W
Maytag MSD2651HES Ref - SXS/I&W
Maytag MSD2651HEW Ref - SXS/I&W
Maytag MSD2651KES Ref - SXS/I&W
Maytag MSD2651KEU Ref - SXS/I&W
Maytag MSD2651KGB Ref - SXS/I&W
Maytag MSD2651KGW Ref - SXS/I&W
Maytag MSD2652KEB Ref - SXS/I&W
Maytag MSD2652KES Ref - SXS/I&W
Maytag MSD2652KEU Ref - SXS/I&W
Maytag MSD2652KEW Ref - SXS/I&W
Maytag MSD2652KGB Ref - SXS/I&W
Maytag MSD2652KGW Ref - SXS/I&W
Maytag MSD2654FRQ Ref - SXS/I&W
Maytag MSD2654FRW Ref - SXS/I&W
Maytag MSD2654GRQ Ref - SXS/I&W
Maytag MSD2654GRW Ref - SXS/I&W
Maytag MSD2655HEB Ref - SXS/I&W
Maytag MSD2655HEQ Ref - SXS/I&W
Maytag MSD2655HES Ref - SXS/I&W
Maytag MSD2655HEW Ref - SXS/I&W
Maytag MSD2656DEB Ref - SXS/I&W
Maytag MSD2656DEQ Ref - SXS/I&W
Maytag MSD2656DEW Ref - SXS/I&W
Maytag MSD2656GEB Ref - SXS/I&W
Maytag MSD2656GEQ Ref - SXS/I&W
Maytag MSD2656GEW Ref - SXS/I&W
Maytag MSD2656KES Ref - SXS/I&W
Maytag MSD2656KEU Ref - SXS/I&W
Maytag MSD2656KGB Ref - SXS/I&W
Maytag MSD2656KGW Ref - SXS/I&W
Maytag MSD2657HEB Ref - SXS/I&W
Maytag MSD2657HEQ Ref - SXS/I&W
Maytag MSD2657HES Ref - SXS/I&W
Maytag MSD2657HEW Ref - SXS/I&W
Whirlpool MSD2658KES00 Refrigerator
Maytag MSD2658KES00 Refrigerator
Whirlpool MSD2658KES01 Refrigerator
Maytag MSD2658KES01 Refrigerator
Whirlpool MSD2658KEU00 Refrigerator
Maytag MSD2658KEU00 Refrigerator
Whirlpool MSD2658KEU01 Refrigerator
Maytag MSD2658KEU01 Refrigerator
Whirlpool MSD2658KGB00 Refrigerator
Maytag MSD2658KGB00 Refrigerator
Whirlpool MSD2658KGB01 Refrigerator
Maytag MSD2658KGB01 Refrigerator
Whirlpool MSD2658KGW00 Refrigerator
Maytag MSD2658KGW00 Refrigerator
Whirlpool MSD2658KGW01 Refrigerator
Maytag MSD2658KGW01 Refrigerator
Maytag MSD2659KEB Ref - SXS/I&W
Maytag MSD2659KEQ Ref - SXS/I&W
Maytag MSD2659KES Ref - SXS/I&W
Maytag MSD2659KEW Ref - SXS/I&W
Maytag MSD265MHEB Ref - SXS/I&W
Maytag MSD265MHEQ Ref - SXS/I&W
Maytag MSD265MHES Ref - SXS/I&W
Maytag MSD265MHEW Ref - SXS/I&W
Maytag MSD265RHEB Ref - SXS/I&W
Maytag MSD265RHEQ Ref - SXS/I&W
Maytag MSD265RHES Ref - SXS/I&W
Maytag MSD265RHEW Ref - SXS/I&W
Maytag MSD2660KES Ref - SXS/I&W
Maytag MSD2660KGB Ref - SXS/I&W
Maytag MSD2660KGW Ref - SXS/I&W
Whirlpool MSD2669KEA00 Refrigerator
Maytag MSD2669KEA00 Refrigerator
Whirlpool MSD2669KEA01 Refrigerator
Maytag MSD2669KEA01 Refrigerator
Whirlpool MSD2669KEB00 Refrigerator
Maytag MSD2669KEB00 Refrigerator
Whirlpool MSD2669KEB01 Refrigerator
Maytag MSD2669KEB01 Refrigerator
Whirlpool MSD2669KEW00 Refrigerator
Maytag MSD2669KEW00 Refrigerator
Whirlpool MSD2669KEW01 Refrigerator
Maytag MSD2669KEW01 Refrigerator
Whirlpool MSD2669KEY00 Refrigerator
Maytag MSD2669KEY00 Refrigerator
Whirlpool MSD2669KEY01 Refrigerator
Maytag MSD2669KEY01 Refrigerator
Maytag MSD2722GRQ Ref - SXS/I&W
Maytag MSD2722GRW Ref - SXS/I&W
Maytag MSD2732GRQ Ref - SXS/I&W
Maytag MSD2732GRS Ref - SXS/I&W
Maytag MSD2732GRW Ref - SXS/I&W
Maytag MSD2734GEQ Ref - SXS/I&W
Maytag MSD2734GEW Ref - SXS/I&W
Maytag MSD2735GRB Ref - SXS/I&W
Maytag MSD2735GRQ Ref - SXS/I&W
Maytag MSD2735GRS Ref - SXS/I&W
  #2 (permalink)
Old 07-12-2012, 01:48 AM
Senior Expert
APP Volunteer
denman is just really nice
Default
I cannot find info on this model number. Here is what comes up when I search
Replacement parts for MSD2464GE models | AppliancePartsPros.com
Please check iy.
If the unit is otherwise running OK then I would say the heater and defrost system are OK. That is why there is water/ice at the bottom of the freezer.
Sounds like drain tube is plugged so that the water from the defrost cycle cannot drain into the drain pan.
I would check that it is clear.
If plugged a turkey baster with warm water, an air compressor with low pressure or a wire can often be used to clear it.
Also check that it is not plugged with dust etc. at the drain pan end.
You might as well clean the condenser/compressor fan and the condenser coils while you are down there.
If it looks like stuff is growing in the tube I would flush it with a 10% bleach solution. This should kill the stuff and let you flush it out. You may have to do this several times, let it sit for 15 minutes or so between flushes.
Be careful that the drip tray does not overflow and empty the drip tral after you are done.
Also check that the drain pan under the evaporator coils is clean. Dirt/crud here can slow down the water flow giving it time to freeze.
Be sure to unplug the unit while doing this.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Freezer water collecting @ bottom of Freezer JohnnyU Refrigerator & Freezer Repair 0 07-08-2012 07:49 AM
Ice in bottom of my LG freezer & water on floor dutchreagan Refrigerator & Freezer Repair 1 04-06-2012 02:49 AM
frost in freezer water under crisper bottom freezer fixtec90 Refrigerator & Freezer Repair 1 06-07-2011 06:42 PM
water freezes in bottom of freezer fatangel Refrigerator & Freezer Repair 1 03-16-2011 07:08 AM
water/ ice in bottom of freezer blford Refrigerator & Freezer Repair 1 01-22-2009 04:21 PM
