When I let the door close by itself, it does not close shut and the ice starts forming around the freezer drawers and other plastic covers. One of the drawers got closed due to ice and does not open anymore. I contacted Samsung, but this happened within two months after the warranty and they will not take care of it anymore without charges. Any help will be appreciated. Thanks a Lot!!!
Groups: APP Team
Hi.
Please provide the model number of the unit. I'll try to assist you.
Simon.
Hi Simon, Here is the model and serial numbers: Model: RS277ACPN/XAA Serial: A93542BS602680B Thanks for your help. Samar
Groups: APP Team
Hi. Remove the freezer door and check the cam risers (upper and lower). They are interlocking and that's what keep the door closed. You may need to order the lower hinge assembly, because the lower cam not available. The door cam Part number: DA66-00344A
