Clogged Defrost Drain?
Hi everyone,
I'm sorry if there are some steps that I should have done before posting. However, I suspect that I have a clogged defrost drain.
The symptoms are that the Freezer is fine but the Lower Fresh Food Compartment was not getting cold enough. I tried to adjust the temperature settings to max but now the Fresh Food Compartment is at room temperature.
I noticed that water was leaking from the top portion of the compartment by the light. I read around a few sites that it may be a clogged defrost drain. I am out of work now, so I really can't afford to call a repair man.
I tried to unscrew a few panels in the freezer to see if I could find something but they didn't seem to be able to removed without possibly breaking them.
I wanted to know the correct way to remove the panels so I could get to the defrost drain. Also the Refrigerator is in a VERY cramped area. I live in a 1 bedroom and the there is really BARELY enough room to get the fridge in and out, so it's not easy to get to the back.
Any help is appreciated. Thanks.
Ads By Google
Related Models
