Hello, I need some help. The frig side is warm and the freezer works. In reading some of the posts i noted to measure the blue defrost wire to orange and I get 27 ohms. that sounds like the main control board is bad along with defrost heater and defrost thermostat. If this is true, how hard is it to replace this stuff and is it worth it on a 10 year old frig? I have replaced the defrost heater once already and installed the heater for the cold water dispenser. Thanks so much for your help.
