Discuss
Amana side-by-side refrigerator ice maker.
 in
Refrigerator & Freezer Repair
My wife left a glass of ice cubes that came from our refrigerator ice maker (IM) on the counter the
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana side-by-side refrigerator ice maker.
  #1 (permalink)
Old 01-26-2008, 02:51 PM
Larry.Jenkins Larry.Jenkins is offline
Junior Member
Larry.Jenkins is on a distinguished road
Default Amana side-by-side refrigerator ice maker.
Model Number: SRD22S5W   Brand: Amana   Age: More than 10 years
My wife left a glass of ice cubes that came from our refrigerator ice maker (IM) on the counter the other night. During the night, they thawed out and there was an opaque film on the top of the melted water and on the sides of the glass.
To determine if the incoming water to the IM was the cause, I drew out some water from the drinking water side of the IM, froze it into cubes and let them melt overnight. The was NO residue, making me think that the part of the IM that makes the ice cubes is dirty.
A possible cause of the contamination could be that the IM was not used for about a month because of a suspected water solenoid valve leak, which turned out to be a loose fitting.
Also, because the original water flow was only a trickle due to a clogged, original supply line, I rerouted the IM water supply and used a drill-type saddle valve, and the new, white braided hose made especially for IMs. Water flow pressure is great.
Because I'm thinking the IM is contaminated, are there any diagrams or instructions available to show how to remove and clean the IM, or do you think it's another cause. If so, please help.
Thank you.
Larry Jenkins
VIEW DIAGRAMS AND PHOTOS, ORDER PARTS
  #2 (permalink)
Old 01-28-2008, 01:00 PM
kooler kooler is offline
Senior Expert
APP Volunteer
kooler is on a distinguished road
Default flush it out
It may be just a matter of dumping out all the ice in the reservoir and letting it refill and dumping the reservoir a second or even third time... Then perform your test again to see if the residue disappears... Otherwise the IM can be removed for hand cleaning by removing the reservoir and removing the screws that hold the IM in place and unplugging the wire assembly... On a lot of models the two top screws only have to be loosened to be able to remove the IM...
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
side by side refrigerator /freezer blows warm air truleygood Refrigerator & Freezer Repair 3 12-28-2007 03:19 AM
Amana side by side freezer not cooling gunner Refrigerator & Freezer Repair 1 12-03-2007 04:30 PM
amana SDC25TL side by side coil frozen..why? weel Refrigerator & Freezer Repair 3 11-19-2007 09:14 PM
Amana Side by Side Refrigerator Evaporator Fan Question beachesfour Refrigerator & Freezer Repair 1 10-17-2007 04:10 AM
Amana Side by Side Refrigerator Freezer MFG. P1317202WE josephbowles@earthlink.ne Refrigerator & Freezer Repair 0 08-10-2007 06:38 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15
