brianhale
#1 Posted : Tuesday, July 3, 2012 9:24:53 AM(UTC)
brianhale
I have a Kenmore Coldspot model 106.55502400. The icemaker stopped making ice. The water to the door works just fine. I replaced the actual icemaker and still no ice. I replaced the water valve (solenoid) and made sure the lines are clear. No ice. What next? I am beyond stumped. Any help is greatly appreciated.
Simon / APP Team
#2 Posted : Tuesday, July 3, 2012 10:43:04 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
When you replaced the icemaker did you change the wire harness too or used the old one?
Measure the freezer temperature.( Should be around 0*F.)
Check for 120VAC at the plug (black to white).
Thank you. Post the results.
Simon.
brianhale
#3 Posted : Tuesday, July 3, 2012 11:12:47 AM(UTC)
brianhale
I did use a new harness. It is near 0. I can pour water into the maker and it freezes. I do not have the ability to check the plug. Everything else is functioning properly.
Simon / APP Team
#4 Posted : Tuesday, July 3, 2012 11:34:00 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Try to jump start the icecmaker. Use the jump wire 14 gauge to connect test points T and H. Remove the wire after 3 sec.
This should initiate the water fill.
If nothing happens, you will need to check the voltage between L and N 120VAC.
Thank you.
Simon.
