freezer and fridge get to about 50 degrees. Compressor runs constantly. The condensor in the freezer compartment has ice on the upper portion of the coils, not the entire coil. All fans are running. Any suggestions and if so can I quickly isolate the problem to get the right part. I do have test meters and a little electrical knowledge. Thanks, Ron
THIS FORUM IS DEAD!!!!!!! |
