Discuss
LG refrig no longer cooling and clicking
 in
Refrigerator & Freezer Repair
Hello- I have an LG brand refrigerator Model LRBN25514ST that has stopped cooling in both the freezer section (bottom) and
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » LG refrig no longer cooling and clicking
  #1 (permalink)
Old 07-02-2012, 01:44 PM
Junior Member
okii is on a distinguished road
Unhappy LG refrig no longer cooling and clicking
Model Number: LRBN25514ST   Brand: -other-   Age: 5 - 10 years
Hello-
I have an LG brand refrigerator Model LRBN25514ST that has stopped cooling in both the freezer section (bottom) and the refrig section. The fridgerator makes a clicking sound periodically. The interior light and temp setting numbers in the fridge still light up. Is there a fuse on the PCB that may have blown? Or could this be some other malfunction. Thanks
Ads By Google
Related Models
Maytag LRSC20A Ref - Sxs
Maytag LRSD20A Ref - Sxs
Maytag LRSD22A Ref - Sxs
Maytag LRSD24A Ref - Sxs
Maytag LRSW22A Ref - SXS/I&W
Maytag LRSW24A Ref - SXS/I&W
Maytag LRTC15A Ref - Top Mount
Maytag LRTC17A Ref - Top Mount
Maytag LRTC19A Ref - Top Mount
Maytag LRTD17A Ref - Top Mount
Maytag LRTD19A Ref - Top Mount
Maytag LRTD21A Ref - Top Mount
Maytag LRTD23A Ref - Top Mount
Maytag LRTS17A Ref - Top Mount
Maytag LRTS19A Ref - Top Mount
Maytag LRTW22A Ref - Top Mount/ I&W
  #2 (permalink)
Old 07-02-2012, 02:03 PM
Senior Expert
APP Volunteer
richappy is a name known to all
Default
Feel the compressor, is it hot and vibrating, or just hot, or cold.
__________________
  #3 (permalink)
Old 07-02-2012, 02:44 PM
Junior Member
Default
Quote:
The compressor (black round shaped unit) is hot. Is it not suppose to be that temperature? I unplugged the fridge before removing the back cover plate so I don't know if it was vibrating. If important to diagnose the problem, I will plug in and check for vibration. Thanks
  #4 (permalink)
Old 07-02-2012, 03:00 PM
Junior Member
Default
I plugged the fridge back in. A fan started a short time after that which blew air into the area around the compressor. A short time after that, there was a "click" sound heard from the back area. The compressor never vibrated during this period of about a minute .
  #5 (permalink)
Old 07-03-2012, 06:35 AM
Junior Member
Default
Hello? Anybody there?
  #6 (permalink)
Old 07-03-2012, 08:45 AM
Senior Expert
APP Volunteer
Default
You have a bad start device on the side of the compressor.Just pull the side cover off, note which wires go where and remove it. If it shakes when rattled,It's bad. or just check with a meter should be 5- 10 ohms.
Sorry, I was working when you responded.
__________________
  #7 (permalink)
Old 07-04-2012, 03:17 PM
Junior Member
Default
No worries. Thanks for responding. Took out the starter relay and overload. Both rattled and small pieces (of insulation?) fell out. Ordered new ones of each.
Ps. Do you ever have to replace the "freon" on these newer fridges? I know they don't actually use freon anymore, but I can't recall what the newer coolant is called.
  #8 (permalink)
Old 07-05-2012, 07:59 AM
Senior Expert
APP Volunteer
Default
If the fridg is cooling at "normal " temperatures, you have no refrigerant leak.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Fridge No Longer Cooling TooManyHobbies Refrigerator & Freezer Repair 4 12-16-2011 02:15 AM
GE S/S making clicking nosie & no longer cooling/freezing??? TLC MOM Refrigerator & Freezer Repair 2 06-19-2011 12:15 PM
Window A/C No Longer Cooling jdential Heating, Ventilation, and Air Conditioning (HVAC) 3 05-08-2010 06:16 PM
Frige and Freezer no longer cooling greasyjeep Refrigerator & Freezer Repair 1 04-27-2010 04:48 AM
whirlpool no longer cooling 7 years old rmeeks Refrigerator & Freezer Repair 1 03-21-2010 11:10 AM
