Register | FAQ's | New Posts | Today's Posts | Extras |
» GE Freezer temperature fluctuates between -7 and +4 |
![]() Model Number: PSS26SGPASS Brand: GE Age: 5 - 10 years
![]() The GE Side-by-Side Freezer temperature was fluctuating between -7 and +4. The temperature is set at -3. After reading the post from "Gene" 01-23-2012, 07:07 PM "Locate the 3-way valve on the back of the refrigerator (#988 on the diagram). Disconnect the refrigerator from power for about a minute, place a finger on top of the valve, and reconnect power. You should be able to feel the valve vibrate as the coil moves the magnet to the home position." Post location: http://forum.appliancepartspros.com/...406733-freezer I was not able to find the 3-way valve Gene identified...I disconnected the refrigerator (I heard a viberation) for 5 or 10 minutes - reconnected. after 24 hours the range seems to be from -6 to 0. Questions: 1) is this a normal range? 2) Should this "3-way" valve be replaced? (if yes - where is it?...I have looked at the drawings without finding) Thank you in advance for your help - THP Related Models |
See inside of your appliance - diagrams and part photos for virtually every model.![]() powered by AppliancePartsPros.com |
![]() Quote:
2. The thread you are referring to is for a different model number. Not all refrigerators are the same and you have to be more careful when you are looking for any advice. There is no 3-way valve in your refrigerator. What exactly is wrong with your refrigerator besides the temperature issue in the freezer? Gene. Gene.
__________________
Appliance Repair Expert in Orange County, California. Order Appliance Parts with 365-Day Hassle Free Return Policy - AppliancePartsPros.com |
![]() Gene,
What a pleasant surprise for you to fine this...I had given up, thank you for taking time!!! 1. I found it by doing a "google search"...this is how I found Appliancepartspros.com. 2. To the best of my knowledge, nothing. is wrong other than the wide range of temperatures in the freezer. UPDATE - I have seen the freezer temperature range from -6 to +5 Believe me, I hope this is normal for this refrigerator. Is it? Thank you for your interest and support. thp |
![]() So far I don't see any serious problem with it. The best way to check the temperature is to use a good refrigerator thermometer. It's better than rely on a digital displays.
- One of the refrigerator thermometers Part number: FG80K Gene.
__________________
![]() You are welcome. Keep us posted and good luck with your fridge.
__________________
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
Oven temperature fluctuates | goodebascomb | Oven Repair (including Ranges and Cooktops) | 0 | 11-28-2011 10:19 PM |
Display cooler temperature fluctuates, clicking at rear temp setting knob | Steve32089 | Refrigerator & Freezer Repair | 1 | 08-24-2011 01:58 PM |
Oven Temperature Fluctuates | tsar | Oven Repair (including Ranges and Cooktops) | 0 | 01-27-2010 12:27 PM |
Whirlpool Oven temperature fluctuates | davcinoz | Oven Repair (including Ranges and Cooktops) | 1 | 11-27-2009 09:42 AM |
Temperature fluctuates in upper oven... | FDAR | Oven Repair (including Ranges and Cooktops) | 1 | 08-16-2008 08:45 PM |
