| » Refrigerator warm, freezer partially defrosted |
Model Number: ED22ZRXAW00 Brand: Whirlpool Age: More than 10 years
My refrigerator stopped working properly. Here are the symptoms:
- Refrigerator side is not cooling - Freezer side is only cold in lower area - Frost accumulates on the evaporator I took everything out of the refrigerator and freezer. While trying to figure out what was wrong with it, I noticed the following: When refrigerator and freezer thermostat knobs are turned on: - Evaporator gets cold and frosts up - Airflow fan doesn’t run When refrigerator and freezer thermostat knobs are turned off: - Evaporator not getting cold (a motor stops running) - Airflow fan starts running (except when both light switches are pushed) - Lights in both refrigerator and freezer aren’t working I tried replacing the defrost timer, but that didn’t work. Don’t know what to try next. Ads By Google Related Models |
Quote:
One thing that I did not mention in my original post is something that preceded the symptoms. The airflow hole at the bottom of the refrigerator near the meat drawer had been obstructed by the drawer being pushed up against the adjustable slide. Frost had also accumulated around that area. |
test your defrost heater and also check the drain hole in the bottom back of the freezer to make sure that not clogged. if so use a turkey baster with some hot water to force any gunk that may have built up down the hole. also check the thermostat to make sure that the fresh food section is cooling properly.
Quote:
For richappy2, I would appreciate it if you would not but into my response, not professional.
Pull off the freezer back panel and describe the frost pattern, total frost, or partial.
__________________
The frost appears mostly at the top of the evaporator, with a small amount of frost also at the bottom right.
About a month ago, I cleaned the condenser coils under the refrigerator with a vacuum. I wouldn't think that would be a factor with the problem. |
Check the back of the fridg. if the compressor is hot, the condensing coils clean and not uniformly hot and the condensing fan moving, you probably have a bad compressor/and,or a refrigerant leak. Guages and amprobe would confirm.
__________________
The compressor should be vibrating and the small diameter tubing going to the condenser should be very hot, probably best to get a pro to look at it, sure seems like a bad compressor.
__________________
| Display Modes | |
| Refridgeraor not very cold and everything in freezer has defrosted. | marrose | Refrigerator & Freezer Repair | 0 | 10-22-2011 04:40 PM |
| The fridge is warm and the freezer partially freezes | Lvtigress | Refrigerator & Freezer Repair | 3 | 03-23-2010 08:48 AM |
| Older Norge Refrigerator Must Be Defrosted | smath1234 | Refrigerator & Freezer Repair | 1 | 11-29-2009 07:14 PM |
| freezer defrosted | cjddmk09 | Refrigerator & Freezer Repair | 0 | 09-26-2009 01:22 PM |
| GE freezer defrosted and fridge too warm | dcarrillo04 | Refrigerator & Freezer Repair | 0 | 08-02-2009 11:09 AM |
