| » Defrost thermostat terminal style mismatch |
Model Number: 59669872990 Brand: Kenmore Age: More than 10 years
I recently purchased a replacement defrost thermostat from APP for a Kenmore refrigerator/ bottom freezer, model 59669872990. I used the site's part selector for my model and ordered the specified part (which is a substitute part from Whirlpool, the OEM).
As seen in the picture, the connectors on the brown leads are different [original = round; part received = rectangular]. Is there a different part that should have been specified? Or, will I need to cut off the connector (on the refrig. or thermostat end), acquire an appropriate terminal from somewhere, and crimp it on? Or, is there a ready-to-use adapter for this? I know that Searspartsdirect.com also indicates a part substitution (possibly with the same mismatch?), so the error is probably on Whirlpool/ Sears end. APP customer service told me that I could return it for a full refund if necessary, but that I should check here first. I'd like to make it work. Any suggestions would be appreciated. -Eric Related Models |
I would cut the connectors off and use a couple wirenuts (murrets) to install the thermostat.
Force a defrost to make sure it works. If OK fill the open end of the wire nut with calking (silicone) Then twist tie or zip tie the wirenuts to a place where the open end will face down (just an extra precaution to keep water out of your connection.
__________________
| Display Modes | |
| defrost thermostat | Davis5000 | Refrigerator & Freezer Repair | 1 | 07-21-2009 01:20 PM |
| Defrost thermostat replacement | kelly b | Refrigerator & Freezer Repair | 2 | 06-23-2009 07:57 PM |
| Defrost thermostat | RAS | Refrigerator & Freezer Repair | 4 | 05-27-2009 05:28 AM |
| Defrost thermostat | John Dulaney | Refrigerator & Freezer Repair | 8 | 11-02-2008 02:59 PM |
| Defrost Thermostat | dgwolfe | Refrigerator & Freezer Repair | 4 | 03-15-2008 06:21 AM |
