BRAND: Fridgidaire MODEL: FLSC23F6DSN
Two basic questions: 1. What tells the main board when it need to defrost? :confused:
I have a refrigerator that is capable of defrosting if I manually start the defrost cycle via a service keystroke sequence. The issue is it doesn't do it on it's own, and froze over the evaporator.
2. What is the normal defrost cycle time? How long should I let my unit run before it defrosts? (ADC vs. Timed)
I did a lot of tinkering, and testing, but didn't know how to start the sequence manually until AFTER I did. If I had a loose wire or bad connection, I may have fixed my issue. :cool:
64 views, and no opinions? :(
I need to be sure before a spend a lot of money on a Main board its not a something simple.
So much information here it mkes one think.....:p Too much sometimes.:rolleyes:
I'm wondering now about the role the thermistors play in this. My fridge has two. :confused:
