Freezer won't cool below 58 degrees. Upon inspection coil was completely frozen. Have checked heating element and thermal couple both Okay. How can I tell if it's the control electronic assembly? Or where would I go from here? How do you remove the control electronic assembly? does it pry out, or do you have to remove the inside panel?
Groups: APP Team
Hi. Check the defrost heater and defrost thermostat when it's ice cold for continuity. If they both are good -then replace the control board Part number: 297366300
how do you remove the electronic control board from the door?
Groups: APP Team
Hi.
Could not find any instructions, but I would use the putty knife around the bezel and pull the control out.
Simon.
