Frigidaire side-by-side ice maker
Model Number: FRS26LR5CWO Brand: Frigidaire Age: 5 - 10 years
My ice maker has stopped making ice! Last week I had some well work done which produced quite a bit of sediment, and I don't believe the ice maker was in the off position when the water came back on two days later. Before that, the water dispenser barely drizzled water so we gave up on that a long time ago. I've replaced the filter and checked all lines in back of the frig. Water pressure from shut-off fine, etc. Purchased a new inlet valve and took the water filter off (needs replacing, but manual says it will work fine without). Water dispenser is now working BEAUTIFULLY but still no ice. The ice maker arm is moving up and down as it would trying to dispense and I'm hearing the motor turning on and off occasionally. It's been reconnected for about 11 hours now. It seems that the water is not flowing down the water chute but I've taken that water line off and the water IS getting to the chute location. Any help would be appreciated.
