MJScott
#1 Posted : Thursday, June 28, 2012 8:14:58 AM(UTC)
MJScott
I replaced my ice maker in my Kitchenaid freezer yesterday and it still has not produced any ice. No water in tray yet. It's been about 20 hours now. How long does it normally take to produce the first batch?
Simon / APP Team
#2 Posted : Thursday, June 28, 2012 9:23:49 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What is the complete model number of the refrigerator and what made you think it's bad icemaker?
Thank you.
Simon.
MJScott
#3 Posted : Thursday, June 28, 2012 9:40:13 AM(UTC)
MJScott
Refrig model# KSRP25FNBC00
The tray would always fill up with water and cubes would be frozen. The cubes would be normally be ejected from the tray. Normal operation would occur for 3-4 days and then it would go several days without ejecting the frozen cubes.
Simon / APP Team
#4 Posted : Thursday, June 28, 2012 11:22:39 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check the water valve by switching around solenoid plugs and pressing the water lever at the dispenser.
If the icemaker fills up - then it's ether bad icemaker, loose connection or the optic controls.
Make sure that the control on the right is on. Check the attached file for optics test.
Here are the breakdown diagrams and Replacement parts for Whirlpool KSRP25FNBL00 REFRIGERATOR | AppliancePartsPros.com
Thank you.
Simon.
File Attachment(s):
MJScott
#5 Posted : Thursday, June 28, 2012 11:23:48 AM(UTC)
MJScott
So..old ice maker would make ice. Problem was that is would only eject it occasionally. Replaced with new ice maker, and new one won't even make ice! Help...
MJScott
#6 Posted : Thursday, June 28, 2012 11:26:04 AM(UTC)
MJScott
Thanks - I will try your suggestions.
Simon / APP Team
#7 Posted : Thursday, June 28, 2012 12:56:31 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Try to switch the icemakers. Make sure the optic control is ON.
Simon.
MJScott
#8 Posted : Friday, June 29, 2012 6:40:35 AM(UTC)
MJScott
OK - New Ice Maker finally made some ice cubes more than 36 hours after installation. The ejector arm has rotated to the vertical 12 o'clock position and has not moved beyond that position for several hours and has not ejected the ice. Any ideas???
Simon / APP Team
#9 Posted : Friday, June 29, 2012 9:23:51 AM(UTC)
Simon / APP Team
Groups: APP Team
Put in the old ice maker and see what is going on.
Simon.
