renee haynes
#1 Posted : Monday, September 14, 2009 12:52:54 PM(UTC)
renee haynes
how often should cold air come threw vents in my fridge??
it is cool in there but not cold it seems as if the air is not blowing
threw the vents often enough.I check it and i never feel air coming out the vent when the compressor kicks on .the freezer does fine, nice and cold
#2 Posted : Monday, September 14, 2009 4:13:34 PM(UTC)
What is the exact temperature in the refrigerator and freezer?
renee haynes
#3 Posted : Monday, September 14, 2009 5:17:26 PM(UTC)
renee haynes
freeze 20 degrees ref. 40degrees
#4 Posted : Monday, September 14, 2009 5:28:45 PM(UTC)
The freezer is worse than the refrigerator by the temperature. Can you see a frost build up on the rear panel in the freezer?
renee haynes
#5 Posted : Monday, September 14, 2009 5:53:01 PM(UTC)
renee haynes
yes a little not much
#6 Posted : Tuesday, September 15, 2009 12:39:54 PM(UTC)
Remove the rear panel in the freezer and check how the evaporator is covered with snow. If it's not a light snow and it is blocked then there is a problem with the defrost system. Post the results and we will proceed with the troubleshooting.
renee haynes
#7 Posted : Tuesday, September 15, 2009 4:09:12 PM(UTC)
renee haynes
am worried about taking it a part im afraid i wont be able to get it back togeather might see if i can get someone else to do that for me..:rolleyes:
Will refrgerator work with no defrost timer (Refrigerator & Freezer Repair)
by tarbetb 6/9/2010 2:41:17 PM(UTC)
refrgerator want stay cool (Refrigerator & Freezer Repair)
by Hart 4/23/2009 9:34:15 PM(UTC)
Refrgerator/Freezer (Refrigerator & Freezer Repair)
by edwcher 8/19/2008 1:38:44 PM(UTC)
