| » Frigidaire side by side/ Fridge freezing everything |
Model Number: Frs23bh6cs0 Brand: Frigidaire Age: 5 - 10 years
Frigidaire side by side fridge is freezing.
Model number: Frs23bh6cs0 Freezer seems to be working fine I did turn the fridge side off until I heard the damper door close, then turned it on to setting 2 well below factory setting. Still freezes everything. Please help Thanks James Ads By Google Related Models |
Hi, James.
First adjust the freezer temp to warmer setting. Give it 12hrs and check freezer temperature. See if that make a difference in the refrigerator side. If at let say 0*F in the freezer it still be freezing produce in the fresh food then replace the damper thermostat #21 Part number: 240383703 Use the old insulation tube. Here are the breakdown diagram and Controls replacement parts for Frigidaire FRS23BH6CS0 Frigidaire/refrigerator | AppliancePartsPros.com Thank you. Post the results. Simon.
__________________
Find Appliance Parts at AppliancePartsPros.com - Largest inventory in the U.S. with 91% of all in-stock orders delivered within 2 business days. Thousands of photos and diagrams make it very easy to find the right part. Enter your appliance model here. |
What is the freezer temp.? If it around 0 F - replace the control I mention earlier.
Thank you. Simon.
__________________
Hi.
Replace the cold control. You have the info. Simon.
__________________
You are welcome.
Simon.
__________________
| Display Modes | |
| Frigidaire side by side fridge freezing | jbarbero | Refrigerator & Freezer Repair | 5 | 06-08-2012 05:12 PM |
| GE side-by-side evap. coils freezing, fridge freezing at bottom and not cold at top | jttaylor | Refrigerator & Freezer Repair | 16 | 03-26-2012 12:45 PM |
| Frigidaire Fridge stopped freezing and fresh side is warm | ebraswell | Refrigerator & Freezer Repair | 1 | 02-01-2012 07:25 AM |
| side by side refrigerator - fridge side freezing food, water coming out of freezer | bomb | Refrigerator & Freezer Repair | 8 | 08-30-2011 01:58 PM |
| Frigidaire Professional Series Side by Side freezing refrigerator contents-help | loggergirl | Refrigerator & Freezer Repair | 1 | 11-16-2010 04:42 AM |
