Appliance Repair Forum
-   Refrigerator & Freezer Repair (http://forum.appliancepartspros.com/refrigerator-freezer-repair/)
-   -   Frigidaire side by side/ Fridge freezing everything (http://forum.appliancepartspros.com/refrigerator-freezer-repair/484685-frigidaire-side-side-fridge-freezing-everything.html)
jbarbero 06-27-2012 05:39 PM
Frigidaire side by side fridge is freezing.
Model number: Frs23bh6cs0
Freezer seems to be working fine
I did turn the fridge side off until I heard the damper door close, then turned it on to setting 2 well below factory setting. Still freezes everything. Please help
Thanks James
Simon / APP Team 06-27-2012 06:11 PM
Hi, James.
First adjust the freezer temp to warmer setting. Give it 12hrs and check freezer temperature. See if that make a difference in the refrigerator side.
If at let say 0*F in the freezer it still be freezing produce in the fresh food then replace the damper thermostat #21
Part number: 240383703
Use the old insulation tube.
Here are the breakdown diagram and Controls replacement parts for Frigidaire FRS23BH6CS0 Frigidaire/refrigerator | AppliancePartsPros.com
Thank you. Post the results.
Simon.
jbarbero 06-27-2012 06:27 PM
Thanks for the Quick reply
Awesome! Will try tonight. I'll post the results tomorrow.
James
jbarbero 06-28-2012 05:48 PM
Update
Adjusted the freezer control to warmer temp. No change in fridge. Everything is still frozen.
Simon / APP Team 06-28-2012 06:08 PM
What is the freezer temp.? If it around 0 F - replace the control I mention earlier.
Thank you.
Simon.
jbarbero 06-28-2012 06:43 PM
Update
I'm embraced to say it but I can't find my thermometer. I'm going to go get another tonight and re run the test. I'll post an update
James
jbarbero 06-29-2012 08:52 PM
update
Simon,
Confirmed temp in freezer is just above zero.
James
Simon / APP Team 07-02-2012 10:49 AM
Hi.
Replace the cold control. You have the info.
Simon.
jbarbero 07-03-2012 08:06 AM
Thank you Simon!!!
Thank you so much! I can't tell you how much I appreciate your help.
James Barbero
Simon / APP Team 07-03-2012 11:19 AM
You are welcome.
Simon.
