Discuss
Amana Freezer okay, fridge not working
 in
Refrigerator & Freezer Repair
Hello, I have an Amana Fridge. Fridge on top and freezer on the bottom Model=ARB190ZCW. Recently, the fan was
Appliance Repair Forum > Appliance Repair Help > Refrigerator & Freezer Repair » Amana Freezer okay, fridge not working
  #1 (permalink)
Old 09-14-2009, 12:29 PM
jimh4938 jimh4938 is offline
Junior Member
jimh4938 is on a distinguished road
Default Amana Freezer okay, fridge not working
Model Number: ARB190ZCW   Brand: Amana   Age: 1 - 5 years
Hello,
Recently, the fan was making noise. Much noisier than usual. Then after that the fridge stopped working and its temp rose to just about room temperature. Meanwhile the freezer temp is normal and seems to be working fine. There seems to be an intake vent in the freezer. I'm not sure if this is how the fridge gets cool, but it could be that we blocked the freezer intake to the fridge; and maybe burnt out the fan?? Anyway, looking at the diagrams for this fridge, I see that this fridge has a condenser fan and evaporator fan. There is a thermostat in the freezer and one in the fridge. The one in the freezer seems to be an actual electronic thermostat; turning on and off the compressor. However, the one in the fridge seems to be more of a mechanical linkage. Feels like its opening and closing a vent.
Are there any ideas out there as to what I should be looking for in diagnosing this problem? Is it likely a circulating fan that's gone bad? Am I reading this right and that the fridge doesn't have an electronic thermostat, but rather just a vent control? If so, which fan (evaporator or condenser) is the one that circulates cold air to the fridge?
Thanks for all help!
Jim
Related Models
Amana ARB190ZCW  Ref - Bottom Mounts
Amana ARB1914CB  Ref - Bottom Mounts
Amana ARB1914CC  Ref - Bottom Mounts
Amana ARB1914CSL  Ref - Bottom Mounts
Amana ARB1914CSR  Ref - Bottom Mounts
Amana ARB1914CW  Ref - Bottom Mounts
Amana ARB1917CB  Ref - Bottom Mounts
Amana ARB1917CC  Ref - Bottom Mounts
Amana ARB1917CSL  Ref - Bottom Mounts
Amana ARB1917CSR  Ref - Bottom Mounts
Amana ARB1917CW  Ref - Bottom Mounts
Amana ARB194RCB  Ref - Bottom Mounts
Amana ARB194RCC  Ref - Bottom Mounts
Amana ARB194RCW  Ref - Bottom Mounts
Amana ARB2107AB Ref - Bottom Mounts
Amana ARB2107AC Ref - Bottom Mounts
Amana ARB2107AS Ref - Bottom Mounts
Amana ARB2107AW Ref - Bottom Mounts
Amana ARB2109ABR Ref - Bottom Mounts
Amana ARB2109ACR Ref - Bottom Mounts
Amana ARB2109ASR Ref - Bottom Mounts
Amana ARB2109AWR Ref - Bottom Mounts
Amana ARB210BAC Ref - Bottom Mounts
Amana ARB210BAW Ref - Bottom Mounts
Amana ARB2117AB Ref - Bottom Mounts
Amana ARB2117AC Ref - Bottom Mounts
Amana ARB2117AS Ref - Bottom Mounts
Amana ARB2117AW Ref - Bottom Mounts
Amana ARB2117BB Ref - Bottom Mounts
Amana ARB2117BC Ref - Bottom Mounts
Amana ARB2117BS Ref - Bottom Mounts
Amana ARB2117BW Ref - Bottom Mounts
Amana ARB2205CB  Ref - Bottom Mounts
Amana ARB2205CC  Ref - Bottom Mounts
Amana ARB2205CS  Ref - Bottom Mounts
Amana ARB2205CW  Ref - Bottom Mounts
Amana ARB220RCB  Ref - Bottom Mounts
Amana ARB220RCC  Ref - Bottom Mounts
Amana ARB220RCW  Ref - Bottom Mounts
Amana ARB220ZCB  Ref - Bottom Mounts
Amana ARB220ZCC  Ref - Bottom Mounts
Amana ARB220ZCS  Ref - Bottom Mounts
Amana ARB220ZCW  Ref - Bottom Mounts
Amana ARB2214CB  Ref - Bottom Mounts
Amana ARB2214CC  Ref - Bottom Mounts
Amana ARB2214CSL  Ref - Bottom Mounts
Amana ARB2214CSR  Ref - Bottom Mounts
Amana ARB2214CW  Ref - Bottom Mounts
Amana ARB2217CB  Ref - Bottom Mounts
Amana ARB2217CC  Ref - Bottom Mounts
Amana ARB2217CSL  Ref - Bottom Mounts
Amana ARB2217CSR Ref - Bottom Mounts
Amana ARB2217CW  Ref - Bottom Mounts
Amana ARB224RCB  Ref - Bottom Mounts
Amana ARB224RCC  Ref - Bottom Mounts
Amana ARB224RCW  Ref - Bottom Mounts
Amana ARB2257CB  Ref - Bottom Mounts
Amana ARB2257CC  Ref - Bottom Mounts
Amana ARB2257CSL  Ref - Bottom Mounts
Amana ARB2257CSR  Ref - Bottom Mounts
Amana ARB2257CW  Ref - Bottom Mounts
Amana ARB2259CB  Ref - Bottom Mounts
Amana ARB2259CC  Ref - Bottom Mounts
Amana ARB2259CS  Ref - Bottom Mounts
Amana ARB2259CW  Ref - Bottom Mounts
Amana ARB2517CB  Ref - Bottom Mounts
Amana ARB2517CC  Ref - Bottom Mounts
Amana ARB2517CSL  Ref - Bottom Mounts
Amana ARB2517CSR  Ref - Bottom Mounts
Amana ARB2517CW  Ref - Bottom Mounts
Amana ARB2557CB  Ref - Bottom Mounts
Amana ARB2557CC  Ref - Bottom Mounts
Amana ARB2557CSL  Ref - Bottom Mounts
Amana ARB2557CSR  Ref - Bottom Mounts
Amana ARB2557CW  Ref - Bottom Mounts
Amana ARB8057CB  Ref - Bottom Mounts
Amana ARB8057CC  Ref - Bottom Mounts
Amana ARB8057CSL  Ref - Bottom Mounts
Amana ARB8057CSR  Ref - Bottom Mounts
Amana ARB8057CW  Ref - Bottom Mounts
Amana ARB9058CB  Ref - Bottom Mounts
Amana ARB9058CS  Ref - Bottom Mounts
Amana ARB9058CW  Ref - Bottom Mounts
Amana ARB9059CS  Ref - Bottom Mounts
Amana ARC-1 Range - S/c S/i Ddraft Gas
Amana ARC-100 Range - S/c S/i Ddraft Gas
  #2 (permalink)
Old 09-14-2009, 07:53 PM
denman denman is offline
Senior Expert
APP Volunteer
denman will become famous soon enough
Default
Here are your parts, includes a wiring diagram.
Replacement parts for AMANA ARB190ZCW | AppliancePartsPros.com
Take a look in the Controls section Item 18, this is your damper assembly
I believe it uses a mechanical thermostat instead of closing a switch the thermostat opens and closes the vent mechanically. It regulates the amount of cold air allowed to enter the fresh food section and therefor the fresh food section temperature.
There is a good chance that your only problem is the evaporator fan, it is required to blow cold air from the freezer up into the fresh food section.
It also circulates air in the freezer you ensure that the food is evenly frozen.
Note: Blocking the cold air intake may effect the fresh food section temperature but will not burn out the fan motor. It is not uncommon for the fans to have problems.
__________________
  #3 (permalink)
Old 09-15-2009, 07:54 AM
Junior Member
Default
Thanks for your help Denman.
Does the evaporator fan run continuously, or is there some control that turns the fan on/off?
Not sure I understand your point about the fan though. Looked like you said that my problem might simply be an evaporator fan, but further down, you said that it is uncommon for fans to have trouble. Are you suggesting the fan is the problem, or the damper?
Thanks again for all your help.
Jim
  #4 (permalink)
Old 09-15-2009, 08:13 AM
Senior Expert
APP Volunteer
Default
Yes it runs all the time except when the fridge is in defrost mode
Sorry for the confusion.
I said "It is not uncommon for the fans to have problems." meaning that it is common for fans to have problems.
__________________
  #5 (permalink)
Old 09-15-2009, 01:21 PM
Junior Member
Default
Thanks Denman. I'll look at the fan first. If that's going, then I'll check the damper. Thanks for all your help!
  #6 (permalink)
Old 09-15-2009, 04:09 PM
Senior Expert
APP Volunteer
Default
My pleasure
Sounds like you are almost there
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Amana Refrigerator not cooling, freezer working sordna Refrigerator & Freezer Repair 1 08-11-2009 08:44 PM
Amana Fridge with lower freezer Starr1126 Refrigerator & Freezer Repair 6 07-24-2009 01:33 PM
Freezer fan not working (I think), freezer warm, fridge erratic dachickenfarmer Refrigerator & Freezer Repair 2 05-12-2009 05:57 AM
Fridge too Warm Freezer working; Now both not working daynasha Refrigerator & Freezer Repair 1 09-02-2008 07:04 AM
Fridge too Warm Freezer working; Now both not working daynasha Refrigerator & Freezer Repair 0 09-01-2008 10:14 AM
