Water does not dispense
The water on the door does not dispense. Occasionally it works but not for long. When it does not work the ice maker does not dispense cubed ice. It always crushes it. Is it as simple as replacing the board?
Sean |
Hi Sean,
If the dispenser lights go dim when you push the release lever then the main control board is the culprit. - The main control board Part number: WR55X10942 Here are the breakdown diagrams and Replacement parts for General Electric GSL25JFTABS Refrigerator | AppliancePartsPros.com Gene. |
The light does not go dim.
Sounds like the dispenser control board is the culprit.
- The dispenser control board Part number: WR55X10562 Gene. |
Not the board. Got the new board in today. No difference. Anything else to try?
Sean,
If the dispenser control board did not fix the problem then the solution is to replace the main control board. You can easy return the unneeded part if you ordered it from APP. The part number for the main control board I posted earlier. Gene. |
| All times are GMT -7. The time now is 03:51 PM. |
