Freezer working, Fridge not defrosting, building up ICE
I have a Samsung RS253BASB, the freezer side is working fine but the fridge side is not working properly. I have already changed the sensor and the PCB main board as it was recommended but still did not do the trick. Run a diagnostic test and I am still getting the PLC error and fridge defrost error. What else should I do to check the real problem of my fridge. :confused:
Ice is building up on the Fridge side...... Is it time to give up and buy a new fridge. :( Thank you. |
| All times are GMT -7. The time now is 11:05 PM. |
