I have a wide by side maytag fridge. The face of the divider wall gets hot. I can fix the problem by hand starting the fan in the back. Do I need a new condensor fan or is it some type of a relay problem? also, I'm not sure how to remove the freezer stop basket on the top left side.
Thanks, Dave
Originally Posted by: DAVE FEELEY I have a wide by side maytag fridge. The face of the divider wall gets hot. I can fix the problem by hand starting the fan in the back. Do I need a new condensor fan or is it some type of a relay problem? also, I'm not sure how to remove the freezer stop basket on the top left side.
Thanks, Dave Does sound like you need a new condenser fan. The area you describe is going to get hot if that fan is not running. Below is the part and link to your model. Part number: AP4069289
